Browse Forums Building A New House 1 Feb 16, 2020 7:58 am Hi, Bricks were recently cleaned and attached photos is result. We have chosen an ironed joint off white colour.The ironed joint finish appeared to look good before cleaning per photo. Mortar appears mostly intact and flaky/sandy in some spots if I rub it. Note: bricks were cleaned ~ 4 months after being laid due to other defects. I raised the issue with builder who advised these would be repointed, however the brick layer has only bothered filling large obvious holes. Is this an acceptable finish? I can’t find any standards or guideline to reference regarding mortar finish. I will call in an inspector if necessary before the scaffolding is lowered next week. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7014 1 9498 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8272 |
