Browse Forums Building A New House 1 Feb 13, 2020 4:50 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi everyone Looking for some advice. My frame does not sit on the slab at the edge all the way around. At some parts the slab is protruding a maximum of 40mm. We have an ant barrier in concrete that sits below the slab and this is also where they start the bricks. I have uploaded two pictures to show you what I mean. The worry I have is that water will stay on the 40mm concrete edge and not drain down through the weep holes and cause rot problems with the wooden frame later on. Can anyone advise whether this is acceptable? TIA This is 100% true. You can not hang anything on steel frames. very frustrating 8 4267 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28157 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4412 |
