Browse Forums Building A New House 1 Feb 13, 2020 1:17 pm Hi all - if you are at planning stage and want to view your plans in a 1 to 1 scale - try Walk Thru Floor Plans www.walkthrufloorplanswa.com.au Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The State of the art projection system in our 600m2 facility allows you / your clients to view and Walk Through their floor plans at concept stage on a 1:1 scale – either for Residential or Commercial applications. Our business model allows the ability to move walls / windows / kitchen benches etc etc in live time while clients are on site / mark up changes and email directly back to the builders and or clients the same day We have real sized furniture on wheels – including Beds / toilet and baths / Kitchen Islands, and moveable walls – that the customer can wheel into living areas to get a true sense of their living space – before the pad goes down Along with our projection area on the floor – we now have a vertical Mega Wall – where we can project clients outside elevations and inside cabinetry heights / 3D Flythrough Videos etc etc and any potential views the site may have We have the ability to convert either PDF or Autocad DWG files directly through our system to the projection areas on a 1:1 basis We are now servicing many Builders / Architects and Building designers in Perth, and their associated clients. ALL with very positive feedback from the experience Phone Chadd or Glen - 0861887554 Re: Walk Thru Floor Plans 2Feb 14, 2020 4:41 pm Just out of curiosity what do you do when homes are to big? Our designer provided a 3D walkthrough which was helpful, I’m lucky i can visualise our home, but at 620sqm it wouldn’t fit in your 600m2 facility... Re: Walk Thru Floor Plans 3Feb 14, 2020 4:47 pm hi there - we can physically scroll across the plan - ie - do 3/4 of the plan - then scroll the balance into the projection floor Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8759 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 4017 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16649 |
