Browse Forums Building A New House 1 Feb 11, 2020 2:51 pm Hi, About to owner build a slightly raised timber 3 bedroom house, on a hillside in Tas. The building is to be facing view NNE, and there is a view of a mountain to the west. Please give your opinions, replies, or ideas, suggestions and improvements for this plan? Are there any errors or mistakes? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . Re: Owner build first house- need feedback on plan 4Feb 13, 2020 11:48 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi OnVisual, I have drafted up your plan to create some consistency with the dimensions and layout. This will help when you are on site! Also, is the north point down the page? This will help determine the placement of windows for best solar gain and vistas. Once north is confirmed that will help me help you fine tune the design. Do you have a site survey and contours? Hope this helps a bit, I'm a licenced building designer (QLD) Cheers, Re: Owner build first house- need feedback on plan 5Feb 13, 2020 1:10 pm Hi - If you use a service like ours it will identify minor mistakes and improvements in life sized 1 to 1 scale www.walkthrufloorplanswa.com.au Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner build first house- need feedback on plan 6Feb 13, 2020 2:19 pm Walk Thru Floor Plans WA Hi - If you use a service like ours it will identify minor mistakes and improvements in life sized 1 to 1 scale http://www.walkthrufloorplanswa.com.au Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner build first house- need feedback on plan 7Feb 13, 2020 2:21 pm amilelka Walk Thru Floor Plans WA Hi - If you use a service like ours it will identify minor mistakes and improvements in life sized 1 to 1 scale http://www.walkthrufloorplanswa.com.au Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow that's a really great concept! thank you! - check out the website / Insta or FB Re: Owner build first house- need feedback on plan 9Feb 15, 2020 1:05 am l_vanslyke Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi OnVisual, I have drafted up your plan to create some consistency with the dimensions and layout. This will help when you are on site! Also, is the north point down the page? This will help determine the placement of windows for best solar gain and vistas. Once north is confirmed that will help me help you fine tune the design. Do you have a site survey and contours? Hope this helps a bit, I'm a licenced building designer (QLD) Cheers, Thank you for that, it certainly makes a lot neater and clearer. They have a process here including going through a design stage, survey, contour plan, bush fire, waste water design, etc. But that will all occur when I am closer to the stage of lodging plans. Just now working out what I want to do, what fits the site, and roughly what it will cost, etc. The views are mainly to the north and west but there is also a more difficult view to the east. The sun is difficult esp. mid winter and mid summer. North is straight down the page, so sun warms the kitchen then hits the lounge; so may need to turn the building slightly to the east to warm the house more in the winter; but the western windows need to point to the mountain view. Thanks again 6 55355 Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12507 Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23628 |
