Browse Forums Building A New House 1 Feb 02, 2020 9:03 pm Hi Need some advice on rear set back for small lot. I believe brisbane city council setback for small lot code is 6metres to rear. I want to know if 6m setback is counted from the eves or the wall of the house? My house Would be 5.6m from rear boundary if I count eves. It’s just over 6m if counted from wall. I don’t want to lose eves (450mm), so wanted to know if anyone has experienced this issue. There is $4000 relaxation fee which is pretty hefty and can’t afford to pay and I cant reduce actual house size, only options is to get rid of eves at the back. I really don’t want to lose eves at the back. I will appreciate if anyone can enlighten me on this Many Thanks Re: Rear Setback for small lot - Brisbane city council 2Feb 06, 2020 9:09 am Hi Romy, Below is an extract from the Brisbane City Plan Development code for Small Lots (providing your lot is classed as such). AO7 Development results in a minimum rear boundary setback that is: (a) 6m, where on a lot with an average depth of more than 25m; or (b) on a lot with an average depth of 25m or less: (i) 3m, for a part of a building or structure up to 4.5m high; (ii) 4.5m, for a part of a building or structure over 4.5m high. (c) located within an approved building envelope for the site to the extent of any inconsistency with (a) or (b). Editor's note—in interpreting AO7 refer to the deemed compliance with site cover and setback assessment criteria in section 1.7.6. Is the average depth of your block equal to or less than 25m? If so, you can adopt a rear setback of 3m to the outermost projection (being the eaves). Otherwise the rear setback it will need to be 6.0m to eaves, and you may need to lose the eaves. Hope this helps! https://www.brisbane.qld.gov.au/planning-and-building/planning-guidelines-and-tools/brisbane-city-plan-2014/brisbane-city-plan-2014-document/brisbane-city-plan-2014-document-part-9-development-codes Re: Rear Setback for small lot - Brisbane city council 3Feb 06, 2020 9:18 am Sorry Romy, after doing a bit more digging referencing the "editors note" for A07 I have found the below: 1.7.6 Deemed compliance with site cover and setback assessment benchmarks (1) For the purpose of determining compliance with an assessment benchmark for setback, development is deemed to comply with the assessment benchmark if the development exceeds the assessment benchmark only by reason of the inclusion of an outermost projection which is part of a building or structure that is: (a) an eave of a roof; or (b) a sunhood or the like attached to the wall of a building or structure to provide shade or shelter to the wall. My understanding is that you exceed the development setback, however, only by reason of the outermost projection which is an eave, therefore the development is deemed to comply. Check this over with your Building Designer or Draftsperson. Link for that extract is below. http://docs.brisbane.qld.gov.au/City%20Plan/v17_00_20191129/TEXT/Part%201%20-%20About%20the%20planning%20scheme/Part1.docx Hope that helps! Hello everyone Did anyone recently applied gas abolishment in Brisbane city council area for gas abolishment , we recently purchased a property and applied for gas… 0 462 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8431 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3640 |
