Browse Forums Building A New House Re: Thomas Archer Bayside Build 222Oct 17, 2020 4:50 pm rockedout Leeota Wellbuild Hi all TA build folks! Seems like most on this forum went with corner stacker doors when building with TA. Who went with a recessed option and who went with the standard? Any idea on the cost of recessing? Have also gone for recessed, was just over $1400. Definitely worth the money! We're also going through tender stage with TA at the moment and had requested our corner stacker to be recessed, however in the tender it has a note "Note: Bottom track of sliding door track to finish 5mm +/- 3mm from finished floor level" which shocked me a bit as I thought the whole point of recessing it would be to have no step over or trip hazard. Did anyone else who recessed their stacker have the note that the track would finish 5mm above FFL? If so, has anyone completed their build with that, and is the 5mm noticeable or annoying? We have now requested a "fully flush" sill/frame which should be perfectly flush with the FFL of our living area. I'm guessing the "flush sill" might actually be a different type of door/frame whereas the "recessed" is the same door/frame as normal. The cost of the "flush sill" is about 3 times the "recessed" option, but I think in the long run it will be a small price to pay... This +/- may be dependant on your floor choice. Some timbers are 14mm thick, some 16, some 18mm. When they grind out the channel for your corner stickers, they have no idea (the guts on the saw) what your finished floor is- they just need the channel for the tracks. Another point of note is your alfresco flooring material. Having spent most of Friday afternoon studying zero threshold drains and water ingress- let me tell you there is a bit involved here! My point to my concrete guy was why would I spend the $ to have the tracks recessed only to have a lip or drop with paving? PM me if you have any questions. 🙂 https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Thomas Archer Bayside Build 224Oct 17, 2020 10:31 pm Blacktea2sugars This +/- may be dependant on your floor choice. Some timbers are 14mm thick, some 16, some 18mm. When they grind out the channel for your corner stickers, they have no idea (the guts on the saw) what your finished floor is- they just need the channel for the tracks. Another point of note is your alfresco flooring material. Having spent most of Friday afternoon studying zero threshold drains and water ingress- let me tell you there is a bit involved here! My point to my concrete guy was why would I spend the $ to have the tracks recessed only to have a lip or drop with paving? PM me if you have any questions. 🙂 I think I understand what you're saying that the +/- may be more to do with floor finish than building tolerance, but that aside there is still 5mm (potentially up to 8mm) of track sticking up above the floorboards/tiles level? It's one of those things where I'm not sure if we think it's a bigger problem than it is in practice. 5mm seems like enough to stub your toe/trip on but maybe it's barely noticable? Our stackers are under cover so I'm not sure drainage is required, other than a gentle fall in level away from the house. I'll have to look into this again though at some point. I'm surprised the whole recessed/flush sill thing is not more straightforward. It seems like a simple and obvious thing but seems to create lots of misunderstanding, at least for us! Re: Thomas Archer Bayside Build 225Oct 18, 2020 8:32 am rockedout Blacktea2sugars This +/- may be dependant on your floor choice. Some timbers are 14mm thick, some 16, some 18mm. When they grind out the channel for your corner stickers, they have no idea (the guts on the saw) what your finished floor is- they just need the channel for the tracks. Another point of note is your alfresco flooring material. Having spent most of Friday afternoon studying zero threshold drains and water ingress- let me tell you there is a bit involved here! My point to my concrete guy was why would I spend the $ to have the tracks recessed only to have a lip or drop with paving? PM me if you have any questions. 🙂 I think I understand what you're saying that the +/- may be more to do with floor finish than building tolerance, but that aside there is still 5mm (potentially up to 8mm) of track sticking up above the floorboards/tiles level? It's one of those things where I'm not sure if we think it's a bigger problem than it is in practice. 5mm seems like enough to stub your toe/trip on but maybe it's barely noticable? Our stackers are under cover so I'm not sure drainage is required, other than a gentle fall in level away from the house. I'll have to look into this again though at some point. I'm surprised the whole recessed/flush sill thing is not more straightforward. It seems like a simple and obvious thing but seems to create lots of misunderstanding, at least for us! I thought it seemed simple too. Until now where the logistics of site fall, drainage and voiding timber floor warranties (by flooding your house) all come in to play. Ours is undercover too. That's not the issue. Its the NCC guideline that a zero threshold with no drain has a 25mm fall in first metre away from stickers, and 10mm each metre thereafter. 25mm is a LOT. That is more of an issue to me than the inlay. I've walked across our tracks in socks and there is no discernible lip- that's why we are do keen to keep it that way. Im also thinking the tracks will vary depending on the doors themselves. We have just under 7 m of corner sliders to alfresco- single glazed. (Our balcony slider is DG upstairs and seems more chunky in design- to hand k e the extra weight and thickness presumably. Not sure Im helping or making things worse but I can see there would be variables with doors etc. And 5mm is negligible unless you're carrying a full tray of margeritas and have had a few before attempting that! https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Thomas Archer Bayside Build 226Oct 19, 2020 11:48 am Blacktea2sugars ... 5mm is negligible unless you're carrying a full tray of margeritas and have had a few before attempting that! Re: Thomas Archer Bayside Build 227Oct 22, 2020 11:07 am r_13 Blacktea2sugars ... 5mm is negligible unless you're carrying a full tray of margeritas and have had a few before attempting that! So..... This just happened Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Thomas Archer Bayside Build 228Oct 22, 2020 11:14 am Wow congrats.....party time.....I m happy for you guys. Re: Thomas Archer Bayside Build 229Oct 22, 2020 11:24 am Congratulations. Only another oh 17 months and we might get there too Re: Thomas Archer Bayside Build 230Oct 22, 2020 11:40 am Thats fantastic. Hope you are happy with the results and thank you for such a great job keeping us across your build. Re: Thomas Archer Bayside Build 234Oct 22, 2020 1:36 pm Congratulations! Enjoy your beautiful new home! looking forward to seeing pics of it set up Re: Thomas Archer Bayside Build 237Oct 26, 2020 9:40 pm Blacktea2sugars Hi guys PCI was today. Hours and hours of it, but hey, there's a lot to take in. So of the "issues" relating to Darbecca report, all are agreed upon. 98% are paint here and there. Very happy with the house and finish of everything. So, as promised...cue #PhotoSpam.... Void and stairwellLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bed2Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ THE doorLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master ensLike ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master WIRLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lounge and AlfrescoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen, dining in backgroundLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now, for some reason all of my portrait photos are publishing side on, so as soon as I fix this issue, I'll pop the rest up. Isn't she pretty? Woweeeeee!! I've missed a lot of progress. You're in!!! Congratulations, looks great and so happy that you're happy with it too. Good luck with the move and settling in. x Re: Thomas Archer Bayside Build 238Oct 28, 2020 10:26 am [quote="sminters"][quote="Blacktea2sugars"]Hi guys Today we have blinds going in and wallpaper going on Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Today we have blinds going in, and wallpaper going on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The entry looks fabulous! Waiting on mirror. All void blinds are either hard-wired or remote control Somfy. Lights and fans tomorrow. 👌 https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Thomas Archer Bayside Build 239Oct 28, 2020 1:49 pm And more blinds and paper.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 We spent close to 2 years in a process with TA. It was horrible..... we got to tender, and the first cut was 50% over our budget which "they care such about meeting ". We… 18 27288 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17602 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9565 |
