Browse Forums Building A New House 1 Jan 20, 2020 10:01 am I am in the final stage of build and sent the fence notice to future neighbor. My next door neighbor mentioned that he is in the process of finalizing the build plan and his Garage will be on the boundary. However his build will start after 6 months and I planning to move there next month. Can I please ask your suggestions on following: 1. What are the options I have for the fence till the time neighbor's garage wall is not erected? I need fence for that length to secure my premise (with hot water system on this side). However I may need to take off the fence when he will start building, and then use the garage wall as fence. What is general protocol in such scenarios. Thanks in advance, Best Regards, Abhi B Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Fencing Query: neighbor's garage is on the property boun 2Jan 20, 2020 1:30 pm abhinandan2909 I am in the final stage of build and sent the fence notice to future neighbor. My next door neighbor mentioned that he is in the process of finalizing the build plan and his Garage will be on the boundary. However his build will start after 6 months and I planning to move there next month. Can I please ask your suggestions on following: 1. What are the options I have for the fence till the time neighbor's garage wall is not erected? I need fence for that length to secure my premise (with hot water system on this side). However I may need to take off the fence when he will start building, and then use the garage wall as fence. What is general protocol in such scenarios. Thanks in advance, Best Regards, Abhi B Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had to put in temporary fencing while we were building. Not sure if the cost will fall on you or your neighbour. thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16294 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7074 |
