Browse Forums Heating, Cooling & Insulation 1 Sep 26, 2008 9:44 pm Like many people who have built a house recently we have a solar hot water panel and an instantaneous gas water heater that comes into play when the sun don't shine.
Our instantaneous gas water heater is a Chromagen unit which we learnt today is capable of delivering 26 litres of hot water per minute. Apparently this is enough to run 2 showers at once if required. Some other builders install a unit from the same manufacturer that only delivers 18 litres per minute, and could result in feeling a bit of cold water in the shower when a tap is turned on. I just though I'd post this as a prompt for those about to build to consider the capacity of their booster units to see if it meets their requirements. Geoff - Decophile. Re: Solar hot water systems with instantaneous gas booster 2Sep 26, 2008 9:59 pm Oh, our builder provided 20litre continuous flow, i was wondering what that mean... looks like it is too late for me to change now since i am about to start building Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Solar hot water systems with instantaneous gas booster 4Sep 27, 2008 11:44 am my builder is installing a dux solar sunpro 305 to our house.. I was concerned a 170 litre tank would be too small after reading your post above but I just went out and look at my current hot water system. It is a aquamax 205 which is 155litre. You add 135litres to that for first hour as both can heat 135litres an hour (dux with gas backup).
So the dux I am having installed can hold 15 litres more and it is still main pressured. I have had 6 people in my house all having showers within a two hour timeslot using both showers (both with hi-flow shower heads) and have never run out of hot water with my aquamax. The only thing is the pressure is a bit lower with both showers going but still full hot water temp. So by those estimations my new system should do the job pretty well and be cheaper!! Its OK to change your HWS 5Sep 29, 2008 5:16 pm I am sure if you ask your builder nicely they'll change your hot water system for you.
Go for a evacuated tube solar unit too, they are much more efficient than flat plate, especially in 'non-summer' seasons I'll show you how to keep your new home betwen 15 and 26 degrees celcius all year round - in your buget - GUARANTEED! www.sunrisehomes.net.au Re: Its OK to change your HWS 6Sep 29, 2008 7:34 pm libechacos I am sure if you ask your builder nicely they'll change your hot water system for you. Go for a evacuated tube solar unit too, they are much more efficient than flat plate, especially in 'non-summer' seasons Do you know what type my dux unit is? It says on the website that: The solar collectors contain a multi tube copper way system bonded to a solar absorber plate....... your model? 7Sep 30, 2008 8:25 am i dont know what type your dux model is, what is the model no etc I'll show you how to keep your new home betwen 15 and 26 degrees celcius all year round - in your buget - GUARANTEED! www.sunrisehomes.net.au gas solar hot water 9Sep 30, 2008 2:30 pm Its easy t get confused with all the tewrminology with a TM after it isnt it.
Looks like a good system, but my understanding is that evacuated tubes with gas back up are the better units. Have a look at these sites: http://www.greenlandsystems.com.au/specifications.html http://www.energymatters.com.au/renewab ... cuated.php They just seem to be 40% more efficient in the non-summer periods I'll show you how to keep your new home betwen 15 and 26 degrees celcius all year round - in your buget - GUARANTEED! www.sunrisehomes.net.au I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14073 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
