Browse Forums Building A New House 1 Jan 05, 2020 12:12 pm Hi I am building in Adelaide and I will need a sump pump installed. I was wondering regarding opinion regarding whether these things are better installed by the builder or no Re: Stormwater via builder or not? 2Jan 05, 2020 3:50 pm Get a quote from your builder, I know friends who built 18 months ago and cost was around $10k from their builder for storing stormwater at the rear of their back garden, then pumping up to the road. You may be able to get it cheaper yourself but I guess the cost will be impacted by ease of access to your property and the local council requirements. Re: Stormwater via builder or not? 3Jan 05, 2020 5:17 pm Thanks its expensive and I wonder if there is any advantage if its done via the builder. The independent contractor has quoted me 5K less than the builder. Further more any ideas as to if i can use sump tank water for irrigation of lawns etc Re: Stormwater via builder or not? 4Jan 05, 2020 10:51 pm BROKEANDEXCITED Thanks its expensive and I wonder if there is any advantage if its done via the builder. The independent contractor has quoted me 5K less than the builder. Further more any ideas as to if i can use sump tank water for irrigation of lawns etc Contact your local council in the first instance. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4860 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8467 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7933 |
