Browse Forums Building A New House Re: which side of the brick faces external facade? 7Jan 02, 2020 9:29 pm Varsity I'm struggling with brick selection at the moment and it appears to me there is quite a bit of variation in different batches of Austral bricks. Also the ranges vary from state to state. In the Everyday Range it looks like they have swapped the names of a couple of the colours between the NSW and QLD websites (e.g. Leisure in the QLD brochure looks like Escape in the NSW brochure) What brick have you used? Some of the Character Renovation range in QLD are smooth on the outside face and wire cut (rough) on the inside as well as having more colour added to the face side. Some are wire cut on both sides, but the outside face is more consistent in texture than the inside. When both faces are wire cut the inside face usually has deeper scores and rougher bits than the face side. Hi Varsity, Ours is freedom in Everyday life selection. What if the bricklayer had laid the bricks wrongly like the rougher side was faced outside? Will that be considered a defect? Thanks Re: which side of the brick faces external facade? 8Jan 02, 2020 9:56 pm Hi Superfly1130, I'm pretty sure that is the face side of the Everyday range, the inside is smoother but has more press marks, however the colour looks to me to be more like Unwind in the Qld brochure than Freedom. The NSW brochure has different colours by name and the Austral website seems to be unreliable in what highdef picture it serves up for either State. I agree the best thing to do at the moment is wait until next week and get a sample of Freedom in whichever state you are from Austral and compare actual bricks in natural light. I don't think they are laid incorrectly but I'd call using the wrong brick a defect. Re: which side of the brick faces external facade? 9Jan 04, 2020 5:42 pm Iām not a brick expert, but I would suggest that the end faces of the brick should be the same texture as the face (I.e. the bricked corners are the same texture on both long and short sides of the brick). It looks like that is the case from your photo. Second Time 'Round Re: which side of the brick faces external facade? 10Jan 08, 2020 12:11 pm Thanks for everyone's reply and help. We visited Austral here in NSW and was indeed confirmed that the brick was laid correctly. The only frustrating thing is that the Freedom brick that was supplied to us was from QLD as there is a high demand in NSW. If there's shortage, they will just pull supplies from other states. The shade of our bricks is between NSW Freedom and NSW Unwind. Unfortunately it's beyond our control and it's like them saying to us that we just have to deal with it. We really like the darker shade of Freedom NSW and that's what we have chosen during the colour selection. Has anyone encountered the same issue? Thanks. Re: which side of the brick faces external facade? 11Jan 08, 2020 1:54 pm SF, I ran up against colour variations in batches trying to decide on a brick for our build. We were considering the Qld Character Renovations St Louis brick, but when we went and looked at actual builds with that brick they all seemed to be different colours ranging from tans through browns and red. These two pics are of different houses we were told were both StLouis bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It doesn't show up well in the photos but to my eye the first one is quite red with minimal heavy colour splodges while the second is quite tan with lots of dark colour splodges. I think the differences are great enough to make it problematic preselecting complimentary garage, roof and gutter colours. Just to check up that I was indeed looking at the same brick I went back to the Austral yard and had a look at the packs of bricks in the yard and the next pic shows the different between two packs there. The front row from one pack is very brown compared to the more orange full pack behind. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We eventually decided we couldn't live with the chance the random pack colouring supplied at build time would suite our taste as it would just be a gamble what actual colour the house ended up - more redish or brownish and colouring even or spotted dog look. The batch variations in the Everyday range don't seem as extreme, but I guess it will still be possible to end up with something somewhat lighter or darker than expected from the colour selections sample. Given different state brochures appear to show different sample colours by name, I don't know if it can be considered to fall within normal batch variation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Freedom looks much the same however the rest of them seem very different to me. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re my second point ā yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5642 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12273 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6908 |
