Browse Forums Building A New House Re: KDR - What would you do differently? 3Dec 19, 2019 11:24 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: KDR - What would you do differently? 5Dec 19, 2019 11:36 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: KDR - What would you do differently? 10Dec 20, 2019 4:55 pm Oh and I forgot to mention have done a lot of research on this forum thanks to all the awesome posts. It will be east facing block and we've found a few floor plans that fit our requirements in terms of dimensions, budget and orientation. Worst case scenario we might consider swapping the crossover as the single story house on the left of us (north facing windows) has built close to the boundary and any double story house will most likely trigger overshadowing. So the idea is to swap the garage to that side and build closer to the right boundary instead. Re: KDR - What would you do differently? 11Dec 22, 2019 6:14 pm EpicDNA We have a rough idea, have narrowed down to a few floor plans and two builders but need the block so we can evaluate orientation, over shadowing, etc. This has taken a few months already, but it's all conceptual. During settlement, is there any reason why we can't organise demolition/crossover permits, and then actual demolition (cut services, electrical pit, actual demolition) right after settlement, before we actually choose a builder? Or do we need to choose a builder first. you need to actually own the property to apply for any permits Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8773 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39703 Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2461 |
