i'm really confused now :S
How did you compromise by going 100% her way?
Browse Forums Building A New House Re: Roof - colour bond Vs Tiles? 21Jan 19, 2020 7:28 pm GAZZABABY We are starting our first build very soon. I wanted to go colorbond, but the partner wanted tiles and so we compromised and decided on tiles. But after reading this idk if i actually want to go tiles now. I didnt realise tile cracking and the risk of leaking ceilings (and the subsequent repair of said ceilings) was so common. i'm really confused now :S How did you compromise by going 100% her way? Re: Roof - colour bond Vs Tiles? 22Jan 19, 2020 7:35 pm Tradies walking on roofs , some of which are big guys and regularly break tiles in which not all will say,u got some spare tiles as I broke a few,where colourbond is easy to see where to walk on screw lines and it doesn't crack or move,also feel it is more forgiving during installation as u don't have bad mortar mix problems falling out all too soon ,thus leaking roof can follow. Re: Roof - colour bond Vs Tiles? 23Jan 19, 2020 8:05 pm GAZZABABY We are starting our first build very soon. I wanted to go colorbond, but the partner wanted tiles and so we compromised and decided on tiles. But after reading this idk if i actually want to go tiles now. I didnt realise tile cracking and the risk of leaking ceilings (and the subsequent repair of said ceilings) was so common. i'm really confused now :S Re: Roof - colour bond Vs Tiles? 24Jan 21, 2020 10:19 pm Colorbond! 1. It’s stronger if tradies have to walk on your roof 2. Colorbond will last longer as it’s not prone to cracks and rarely leaks 3. You can hear the rain because why wouldn’t you want to fall asleep listening to rain that’s the main reason I chose it in my home 4. It’s extremely light weight compared to roof tiles 5. It’s harder to break in! It only takes some one to lift a few roof tiles and find the man hole to break in to a house. Re: Roof - colour bond Vs Tiles? 25Jan 22, 2020 6:22 am i typed a massive story a few days ago and then kit clear instead of post our present colorbond house when we bought it, the following leaks rangehood vent pipe, took roof plumber 3 turns to fix conara heater 1 turn to fix skylight 1 turn to fix ensuite ceiling ongoing, every year for 5 years just tried again last week we now keep a folded towel on the floor in case it rains when we are not home you could not pay me to have colorbond again if a roof tile cracks it takes less than 5 minutes to replace if a colorbond sheet gets damaged you have to replace the entire sheet and the tradies leave creases in the colorbond where they step which are very noticeable colorbond the sealing washers need to be replaced every 5 to 15 years or so https://www.google.com.au/search?source=hp&ei=W10nXrvJCpSK4-EPlPyhkAc&q=how+often+to+replace+metal+roofing+screw+washers&oq=how+often+to+replace+metal+roofing+screw+washers&gs_l=psy-ab.3...2398.18117..18368...1.0..0.338.7903.0j48j1j1......0....1..gws-wiz.....0..0i131j0j0i70i251j0i10j0i22i30j0i13j33i22i29i30j33i160j33i21.yX0hFe63DIw&ved=0ahUKEwj74oHCwpXnAhUUxTgGHRR-CHIQ4dUDCAg&uact=5 Re: Roof - colour bond Vs Tiles? 26Jan 22, 2020 10:53 am aussieta i typed a massive story a few days ago and then kit clear instead of post our present colorbond house when we bought it, the following leaks rangehood vent pipe, took roof plumber 3 turns to fix conara heater 1 turn to fix skylight 1 turn to fix ensuite ceiling ongoing, every year for 5 years just tried again last week we now keep a folded towel on the floor in case it rains when we are not home you could not pay me to have colorbond again if a roof tile cracks it takes less than 5 minutes to replace if a colorbond sheet gets damaged you have to replace the entire sheet and the tradies leave creases in the colorbond where they step which are very noticeable colorbond the sealing washers need to be replaced every 5 to 15 years or so https://www.google.com.au/search?source=hp&ei=W10nXrvJCpSK4-EPlPyhkAc&q=how+often+to+replace+metal+roofing+screw+washers&oq=how+often+to+replace+metal+roofing+screw+washers&gs_l=psy-ab.3...2398.18117..18368...1.0..0.338.7903.0j48j1j1......0....1..gws-wiz.....0..0i131j0j0i70i251j0i10j0i22i30j0i13j33i22i29i30j33i160j33i21.yX0hFe63DIw&ved=0ahUKEwj74oHCwpXnAhUUxTgGHRR-CHIQ4dUDCAg&uact=5 Re: Roof - colour bond Vs Tiles? 27Jan 22, 2020 11:12 am Joker aussieta i typed a massive story a few days ago and then kit clear instead of post our present colorbond house when we bought it, the following leaks rangehood vent pipe, took roof plumber 3 turns to fix conara heater 1 turn to fix skylight 1 turn to fix ensuite ceiling ongoing, every year for 5 years just tried again last week we now keep a folded towel on the floor in case it rains when we are not home you could not pay me to have colorbond again if a roof tile cracks it takes less than 5 minutes to replace if a colorbond sheet gets damaged you have to replace the entire sheet and the tradies leave creases in the colorbond where they step which are very noticeable colorbond the sealing washers need to be replaced every 5 to 15 years or so https://www.google.com.au/search?source=hp&ei=W10nXrvJCpSK4-EPlPyhkAc&q=how+often+to+replace+metal+roofing+screw+washers&oq=how+often+to+replace+metal+roofing+screw+washers&gs_l=psy-ab.3...2398.18117..18368...1.0..0.338.7903.0j48j1j1......0....1..gws-wiz.....0..0i131j0j0i70i251j0i10j0i22i30j0i13j33i22i29i30j33i160j33i21.yX0hFe63DIw&ved=0ahUKEwj74oHCwpXnAhUUxTgGHRR-CHIQ4dUDCAg&uact=5 Re: Roof - colour bond Vs Tiles? 28May 13, 2020 8:42 am murtaza.sh I am going to build my first home and selected SJD Homes and are at the pre-contract stage. Can someone highlight the pros & cons of Colour Bond Vs Roof tiles? Short & Long Term? Hi Murtaza who is your builder and where are you building. Our house is under construction and we have selected color bond roof. Most of my friend suggest me and did little bit of research on both roofs. Tiles are old fashioned and want to be standout. Send me what you have ended with tiles or colorbond? Re: Roof - colour bond Vs Tiles? 29May 13, 2020 7:15 pm Hussain sahara murtaza.sh I am going to build my first home and selected SJD Homes and are at the pre-contract stage. Can someone highlight the pros & cons of Colour Bond Vs Roof tiles? Short & Long Term? Hi Murtaza who is your builder and where are you building. Our house is under construction and we have selected color bond roof. Most of my friend suggest me and did little bit of research on both roofs. Tiles are old fashioned and want to be standout. Send me what you have ended with tiles or colorbond? I have also selected colourbond. I was avoiding it due to the additional anticon cost. But at the end we thought to go for it as it look nice with other benefits. I am building in Berwick with SJD Homes. And you? Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Roof - colour bond Vs Tiles? 30May 13, 2020 7:47 pm murtaza.sh Hussain sahara murtaza.sh I am going to build my first home and selected SJD Homes and are at the pre-contract stage. Can someone highlight the pros & cons of Colour Bond Vs Roof tiles? Short & Long Term? Hi Murtaza who is your builder and where are you building. Our house is under construction and we have selected color bond roof. Most of my friend suggest me and did little bit of research on both roofs. Tiles are old fashioned and want to be standout. Send me what you have ended with tiles or colorbond? I have also selected colourbond. I was avoiding it due to the additional anticon cost. But at the end we thought to go for it as it look nice with other benefits. I am building in Berwick with SJD Homes. And you? Building with Henley in Truganina. Re: Roof - colour bond Vs Tiles? 31May 19, 2020 1:13 pm GAZZABABY We are starting our first build very soon. I wanted to go colorbond, but the partner wanted tiles and so we compromised and decided on tiles. But after reading this idk if i actually want to go tiles now. I didnt realise tile cracking and the risk of leaking ceilings (and the subsequent repair of said ceilings) was so common. i'm really confused now :S what did you end up going with, Im so confused too. Hubby wants tile and i want colorbond, just because i like the sound of the rain. Re: Roof - colour bond Vs Tiles? 32May 19, 2020 5:10 pm khusnil.deo GAZZABABY We are starting our first build very soon. I wanted to go colorbond, but the partner wanted tiles and so we compromised and decided on tiles. But after reading this idk if i actually want to go tiles now. I didnt realise tile cracking and the risk of leaking ceilings (and the subsequent repair of said ceilings) was so common. i'm really confused now :S what did you end up going with, Im so confused too. Hubby wants tile and i want colorbond, just because i like the sound of the rain. Brand new double storey $600k plus home near our build just finished and owners have been in about a month A few weeks ago Perth was hit with heavy rain, their new tiled roof has leaked and some of the upstairs ceiling has collapsed. Re: Roof - colour bond Vs Tiles? 33May 20, 2020 11:16 am murtaza.sh Thanks for very useful info. Look forward to hearing few more opinions. What did you end up going with? Im also confused with the roof. So many people in Edmonson Park, NSW their new houses leaked with their tiled roof. We are also in NSW, south west sydney. Re: Roof - colour bond Vs Tiles? 34May 20, 2020 11:45 am khusnil.deo murtaza.sh Thanks for very useful info. Look forward to hearing few more opinions. What did you end up going with? Im also confused with the roof. So many people in Edmonson Park, NSW their new houses leaked with their tiled roof. We are also in NSW, south west sydney. We are going with colour bond roof with Bradford anticon and R3.5 insulation batts for ceiling. Hopefully it will cope with all the issues. Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Roof - colour bond Vs Tiles? 35May 20, 2020 12:02 pm murtaza.sh khusnil.deo murtaza.sh Thanks for very useful info. Look forward to hearing few more opinions. What did you end up going with? Im also confused with the roof. So many people in Edmonson Park, NSW their new houses leaked with their tiled roof. We are also in NSW, south west sydney. We are going with colour bond roof with Bradford anticon and R3.5 insulation batts for ceiling. Hopefully it will cope with all the issues. Hi guys our roof install yesterday and it look beautiful in colorbond surfmist colour. We are happy so far with look. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof - colour bond Vs Tiles? 37May 20, 2020 3:27 pm khusnil.deo GAZZABABY We are starting our first build very soon. I wanted to go colorbond, but the partner wanted tiles and so we compromised and decided on tiles. But after reading this idk if i actually want to go tiles now. I didnt realise tile cracking and the risk of leaking ceilings (and the subsequent repair of said ceilings) was so common. i'm really confused now :S what did you end up going with, Im so confused too. Hubby wants tile and i want colorbond, just because i like the sound of the rain. We’re going with colorbond. Benefits slightly outweighing the cons. Re: Roof - colour bond Vs Tiles? 38Jul 12, 2020 4:25 pm Hi Murtaza.sh, how much did you pay for your Anticon R3.5 insulation? I am bit worried about the cost. Re: Roof - colour bond Vs Tiles? 39Jul 12, 2020 8:31 pm ConfusedSoul Hi Murtaza.sh, how much did you pay for your Anticon R3.5 insulation? I am bit worried about the cost. My Anticon is R1.3 from Bradford https://www.bradfordinsulation.com.au/home-insulation/roofing/anticon for colorbond roof and the cost for the Anticon blanket is $3000 for a 32 Sq house. However, I am using R3.5 batt for ceiling and that is separate. Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Do you have solar on the roof, because if its not a laying defect it looks almost like someone has been walking all over the roof in the mid section of the tile (weakest… 2 1930 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2536 2 9447 |
