Browse Forums Building A New House 1 Nov 26, 2019 3:28 pm Hi everyone, I really need some help with this problem. We built a house with Carlisle in Truganina VIC. After the handover, we booked appointment with opticomm to connect internet, it didn't go well as they said the lead-in conduit pipe was damaged and asked me to contact Carlisle. Carlisle sent a contractor to investigate and they suspect the gas installation damaged in the lead-in conduit and the location(blue cross) is under concrete. see below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then Carlisle told me that "Carlisle homes do not run the gas line, and that it is the responsibility of your gas provider to run this. As they are required to run the gas line to the home, we suggest further discussing this matter with them." I believe Carlisle should be responsible to fix this issue. As the damaged happened during the construction. Any suggestions? Thanks. Re: lead in conduit issue with Carlisle 2Nov 26, 2019 5:48 pm Hello, I feel that the builder should have constructed the paving with due diligence. It would have apparent that there was a defect before pouring the concrete mix (or earlier with the paving form work). It may have well been.damaged during this preparation stage. Re: lead in conduit issue with Carlisle 3Nov 26, 2019 9:28 pm hjmhyl Hi everyone, I really need some help with this problem. We built a house with Carlisle in Truganina VIC. After the handover, we booked appointment with opticomm to connect internet, it didn't go well as they said the lead-in conduit pipe was damaged and asked me to contact Carlisle. Carlisle sent a contractor to investigate and they suspect the gas installation damaged in the lead-in conduit and the location(blue cross) is under concrete. see below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then Carlisle told me that "Carlisle homes do not run the gas line, and that it is the responsibility of your gas provider to run this. As they are required to run the gas line to the home, we suggest further discussing this matter with them." I believe Carlisle should be responsible to fix this issue. As the damaged happened during the construction. Any suggestions? Thanks. Anytime before handover builder is responsible for any damage as builder is in charge and in possession of the site Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: lead in conduit issue with Carlisle 4Nov 27, 2019 8:42 am building-expert hjmhyl Hi everyone, I really need some help with this problem. We built a house with Carlisle in Truganina VIC. After the handover, we booked appointment with opticomm to connect internet, it didn't go well as they said the lead-in conduit pipe was damaged and asked me to contact Carlisle. Carlisle sent a contractor to investigate and they suspect the gas installation damaged in the lead-in conduit and the location(blue cross) is under concrete. see below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then Carlisle told me that "Carlisle homes do not run the gas line, and that it is the responsibility of your gas provider to run this. As they are required to run the gas line to the home, we suggest further discussing this matter with them." I believe Carlisle should be responsible to fix this issue. As the damaged happened during the construction. Any suggestions? Thanks. Anytime before handover builder is responsible for any damage as builder is in charge and in possession of the site Thanks building-expert, so even the conduit was damaged when the gas provider install the service line, Carlisle should be responsible? Are there any document or web page I can refer to? I need something to go back to Carlisle. Thanks. the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2883 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37143 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10228 |
