Browse Forums Building A New House 1 Nov 20, 2019 12:42 pm Dear all, My planned house is of single storey 29 squares with 4 bedrooms, 2 living areas and 1 open theatre . Total of 9 vents are present as per the standard design( 4 in bedrooms and 5 in living/theatre). Below are the price list provide by the builder and I am bit confused with the options to go with. Gas heating : regular one provided by the builder is Brivis 3 star, which cannot have zoning and upgrade to SP series - i.e. 4, 5 or 6 star would be required. Zone upgrade option: Zone Option 1 - Provide Brivis Zone Plus Heating System 2 zones to Single Storey $1,604.00 Includes 1No. Networker Controller (NC6) in lieu of standard programmable controller (included in upgrade to heating unit), 1No.temperature sensor, 2No. zone motors. Zone Option 2 - Provide Brivis Zone Plus Heating System 3 zones to Single Storey $2,223.00 Includes 1No. Networker Controller (NC6) in lieu of standard programmable controller (included in upgrade to heating unit), 2No.temperature sensors, 3No. zone motors. Zone Option 3 - Provide Brivis Zone Plus Heating System 4 zones to Single Storey $2,372.00 Includes 1No. Networker Controller (NC6) in lieu of standard programmable controller (included in upgrade to heating unit), 2No.temperature sensors, 3No. zone motors & 1No. 506 module Unit options: Unit Option 1 - Upgrade heating unit from a Brivis CC3 to SP4 (3 Star to 4 Star) unit, includes upgrade to networker controller in lieu of programmable $959.00 Unit Option 2 - Upgrade heating unit from a Brivis CC3 to SP5 (3 Star to 5 Star) unit, includes upgrade to networker controller in lieu of programmable $1,483.00 Unit Option 3 - Upgrade heating unit from a Brivis CC3 to SP6 (3 Star to 6 Star) unit, includes upgrade to networker controller in lieu of programmable $1,834.00 Evaporative cooling : Brivis Contour L66 unit to 8 points. $7,808.00 Refrigerated air conditioning: 14.80 kW (Nominal cooling capacity) single phase Brivis refrigerated air conditioning to 9 points including upgrade of the heating unit from the Brivis Compact Classic to 5 Star unit - $15,135 (so this includes Unit Option 2, which is builders $1,483.00) I believe refrigerated air conditioning would be reverse cycle, so can be used for both cooling and heating. Yes, included 5 star gas heater would be another option for heating. So the point is, if I upgrade to 5 star gas heater ( $1,483.00) and no zoning + Evaporative cooling ( $7,808.00), it would be $9291 With Refrigerated cooling (5 star gas heater and no zoning), it would be $15,135 Difference is - $5,844 Please note that most of the time around the year, only living and master bed would be used. Also, I will be using more of heating than cooling ( I can bear most of the summer heat, not the cold weather in the peak winter ). I am aware that refrigerative cooling is a closed system and for Evaporative cooling to work, there should be few windows opened. My confusions are, 1) Is it worth upgrading to Refrigerated cooling by paying $5,844 2) Is it worth to upgrade to Brivis Zone Plus in a single storey 29 squares home by paying $1,604.00 for 2 zones. Read somewhere that zoning may not effective in single storey house and anytime at least 6 vents should be open for smooth working of the Gas heating. 3) Is it beneficial to upgrade the gas heating unit to 6 star ( $1,834.00 ) with no zoning and then have Evaporative cooling. It is will be very helpful if you could provide your suggestions based on your experience. Thanks, Shi Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 2Nov 20, 2019 12:46 pm This kind of stuff really is personal preference. I have lived with Evaporative cooling most my life, and only a short part of my life with reverse cycle cooling. It'd take a lot more then $6000 for me to build with Evaporative cooling again. Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 3Nov 20, 2019 2:25 pm I detest Evap cooling with a passion, and have never found it adequate. That being said, depends on location, house construction materials and insulation (reflection of heat etc) Window glazing and curtains/blinds also come into play What are the breezes like? Being single storey, if you have dbl storey neighbours, will you miss out on cooling winds? If it was my budget, I'd do Refrig with option 2 included. Yes I'm sure it will be RC, so you can heat as well. https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 4Nov 20, 2019 2:34 pm Blacktea2sugars I detest Evap cooling with a passion, and have never found it adequate. That being said, depends on location, house construction materials and insulation (reflection of heat etc) Window glazing and curtains/blinds also come into play What are the breezes like? Being single storey, if you have dbl storey neighbours, will you miss out on cooling winds? If it was my budget, I'd do Refrig with option 2 included. Yes I'm sure it will be RC, so you can heat as well. Thank you. I will have double glazing throughout. Its melbourne, at least 10 km areal distance from sea. Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 6Nov 20, 2019 5:35 pm Shi Blacktea2sugars I detest Evap cooling with a passion, and have never found it adequate. That being said, depends on location, house construction materials and insulation (reflection of heat etc) Window glazing and curtains/blinds also come into play What are the breezes like? Being single storey, if you have dbl storey neighbours, will you miss out on cooling winds? If it was my budget, I'd do Refrig with option 2 included. Yes I'm sure it will be RC, so you can heat as well. Thank you. I will have double glazing throughout. Its melbourne, at least 10 km areal distance from sea. Ah ok I'm also in Melbourne, less than 500 metres from the bay, and I still would not trust Evap to cool a double glazed double storey 40 + square house. https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 7Nov 21, 2019 7:03 am amilelka I'm under the impression that the cost of heating by gas is quite high. I would recommend reverse cycle ducted air conditioning. I agree with the above. Having always had evaporative cooling and gas heating in our previous homes, this time we opted for a ducted reverse cycle system to heat and cool the home, and solar panels to help with running costs. And on a personal level, as I get older I find my tolerance to extreme heat is a lot less than it ever used to be, so that sealed the decision. Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 9Nov 21, 2019 12:18 pm Thank you all for the reply.
The problem here is my builder provides Brivis Gas heating + Evaporative cooling as a default option. And then the upgrade option is to a 14.80 kW (Nominal cooling capacity) single phase Brivis add on refrigerated air conditioning, which is Brivis ICE ( Integrated Cooling Equipment). Brivis advertise it as DualComfort - Brivis Gas heating + Brivis ICE. Firstly, I am not a big fan of Brivis, then when I check for user opinions, everyone has hell lots of issues with Brivis ICE cooling. Other confusion is because its combined with gas heating, does that mean it is not capable of reverse cycle heating? also Brivi's AEER ratings for refrigerative cooling is merely around 3.1 and I will endup paying $15,135 for Brivis Gas heating + Brivis ICE. What are the other options? Do you know how much would be the rough estimate for Actron, Panasonic, Samsung, Daikin etc (or any better brands) to have reverse cycle cooling/heating on 29 squares single storey, 2740mm ceiling height, double glazed house based on your experience. Is that something doable altogether post the build? Thanks, Sreejith Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 10Nov 21, 2019 12:53 pm Shi Thank you all for the reply. The problem here is my builder provides Brivis Gas heating + Evaporative cooling as a default and the option. And then the upgrade option is to a 14.80 kW (Nominal cooling capacity) single phase Brivis add on refrigerated air conditioning, which is Brivis ICE ( Integrated Cooling Equipment). Brivis advertise it as DualComfort - Brivis Gas heating + Brivis ICE. Firstly, I am not a big fan of Brivis, then when I check for user opinions, everyone has hell lots of issues with Brivis ICE cooling. Other confusion is because its combined with gas heating, does that mean it is not capable of reverse cycle heating? also Brivi's AEER ratings for refrigerative cooling is merely around 3.1 and I will endup paying $15,135 for Brivis Gas heating + Brivis ICE. What are the other options? Do you know how much would be the rough estimate for Actron, Panasonic, Samsung, Daikin etc (or any better brands) to have reverse cycle cooling/heating on 29 squares single storey, 2740mm ceiling height, double glazed house based on your experience. Is that something doable altogether post the build? Thanks, Sreejith You said before that you will be mainly be using two rooms. Perhaps you could put ceiling fans in bedrooms and split systems in areas you'd like heated/cooled? Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 11Nov 21, 2019 2:11 pm We just did KDR in Melbourne, and our temporary rental had Evap. I am so glad we didn't put it in - it was terrible. Didn't do much on those really hot 40 deg + days, except making it really humid inside. Strongly recommend going for zones, so that you don't have to heat/cool the whole house - I am so glad we did Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 12Nov 21, 2019 4:54 pm Hi, I think you are much better off going with some individual split systems (ie. no ducting). When people talk about zoning, we have the ultimate 'zoned' solution with our 3 Fujitsu splits. We spent around $6500 (incl. rebate) to buy and get the 3 units installed during our build. Our place is single story, living areas total around 25 squares. There are so many reason to go with multiple splits and the only negative I can think of is the aesthetics of the outside condensors. The positives are:
Running any form of ducted heating/cooling in unconditioned roof spaces obviously leads to fairly large energy losses, but I will put my hand up here and point out we did retain our gas central ducted heating system. The builder was offering such a low credit to remove it, it wasn't worth it. We have been in the house for about a month and the splits haven't had to be used too much but I can't see us using the ducted system much at all. Maybe we might turn it on to help distribute conditioned air (by the main 7.1kw split in the living area) around the rest of the house...as our central gas unit has a fan only mode. Anyhow, if you have to go with a centralised ducted system I would certainly attempt to stay full electric and at least with a reverse cycle system (inverter) they are reasonably efficient. --------------------------------------------------------------------- Check our Homeone build blog here Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 13Dec 03, 2019 10:10 pm Hello all, I am new to the forum and started with a thread asking for a cooling related help and no one provide me with the help. Posting the same question here hoping someone will be able help me. I am planning to opt out gas heating and evaporative cooling provided by builder and go completely with reverse cycle refrigerative cooling post the build. Is this got any implications with Builder approval? Is there any rule that ducted Gas or some sort of heating should be there in place for building approval? Thanks Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 14Dec 04, 2019 7:02 am ssyi Hello all, I am new to the forum and started with a thread asking for a cooling related help and no one provide me with the help. Posting the same question here hoping someone will be able help me. I am planning to opt out gas heating and evaporative cooling provided by builder and go completely with reverse cycle refrigerative cooling post the build. Is this got any implications with Builder approval? Is there any rule that ducted Gas or some sort of heating should be there in place for building approval? Thanks As long as your energy rater (as in the 'builder's' energy rater) is OK with leaving off any mechanical systems - which I think is ok from a star rating perspective? - then I don't see a major issue. So basically if your builder is happy to credit you and the energy report doesn't include them either you should be ok. I agree with leaving out ducted systems as they are typically quite inefficient with respect to energy loss via the ducts themselves. They also add penetrations to your ceiling and air return etc. The main thing I would consider is getting this added to your plans/contract as 'owner supplied', so at least you can get the system(s) rough-in all done during construction which is not only cheaper but also much neater/easier. We had 3 separate splits installed during our build and I am glad we did the rough-in at frame stage. It gave us the chance to choose exactly where the drains were located and seal up tears in wall wrap etc. In my opinion now with having our house finished with a ducted gas heating system and also our 3 splits.....I believe our construction industry should ditch ducted systems completely unless they can somehow work out how to run the ducts through a conditioned air space. Multiple splits are the ultimate in zoning and efficiency and we are very happy with ours and wish I had pushed harder to have the central heating system deleted during our design phase. --------------------------------------------------------------------- Check our Homeone build blog here Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 15Dec 08, 2019 12:14 am darb74 ssyi Hello all, I am new to the forum and started with a thread asking for a cooling related help and no one provide me with the help. Posting the same question here hoping someone will be able help me. I am planning to opt out gas heating and evaporative cooling provided by builder and go completely with reverse cycle refrigerative cooling post the build. Is this got any implications with Builder approval? Is there any rule that ducted Gas or some sort of heating should be there in place for building approval? Thanks As long as your energy rater (as in the 'builder's' energy rater) is OK with leaving off any mechanical systems - which I think is ok from a star rating perspective? - then I don't see a major issue. So basically if your builder is happy to credit you and the energy report doesn't include them either you should be ok. I agree with leaving out ducted systems as they are typically quite inefficient with respect to energy loss via the ducts themselves. They also add penetrations to your ceiling and air return etc. The main thing I would consider is getting this added to your plans/contract as 'owner supplied', so at least you can get the system(s) rough-in all done during construction which is not only cheaper but also much neater/easier. We had 3 separate splits installed during our build and I am glad we did the rough-in at frame stage. It gave us the chance to choose exactly where the drains were located and seal up tears in wall wrap etc. In my opinion now with having our house finished with a ducted gas heating system and also our 3 splits.....I believe our construction industry should ditch ducted systems completely unless they can somehow work out how to run the ducts through a conditioned air space. Multiple splits are the ultimate in zoning and efficiency and we are very happy with ours and wish I had pushed harder to have the central heating system deleted during our design phase. Thanks a lot darb74 Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 16Dec 08, 2019 12:14 am darb74 ssyi Hello all, I am new to the forum and started with a thread asking for a cooling related help and no one provide me with the help. Posting the same question here hoping someone will be able help me. I am planning to opt out gas heating and evaporative cooling provided by builder and go completely with reverse cycle refrigerative cooling post the build. Is this got any implications with Builder approval? Is there any rule that ducted Gas or some sort of heating should be there in place for building approval? Thanks As long as your energy rater (as in the 'builder's' energy rater) is OK with leaving off any mechanical systems - which I think is ok from a star rating perspective? - then I don't see a major issue. So basically if your builder is happy to credit you and the energy report doesn't include them either you should be ok. I agree with leaving out ducted systems as they are typically quite inefficient with respect to energy loss via the ducts themselves. They also add penetrations to your ceiling and air return etc. The main thing I would consider is getting this added to your plans/contract as 'owner supplied', so at least you can get the system(s) rough-in all done during construction which is not only cheaper but also much neater/easier. We had 3 separate splits installed during our build and I am glad we did the rough-in at frame stage. It gave us the chance to choose exactly where the drains were located and seal up tears in wall wrap etc. In my opinion now with having our house finished with a ducted gas heating system and also our 3 splits.....I believe our construction industry should ditch ducted systems completely unless they can somehow work out how to run the ducts through a conditioned air space. Multiple splits are the ultimate in zoning and efficiency and we are very happy with ours and wish I had pushed harder to have the central heating system deleted during our design phase. Thanks a lot darb74 Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 17Sep 17, 2020 6:59 pm Shi Dear all, My planned house is of single storey 29 squares with 4 bedrooms, 2 living areas and 1 open theatre . Total of 9 vents are present as per the standard design( 4 in bedrooms and 5 in living/theatre). Below are the price list provide by the builder and I am bit confused with the options to go with. Gas heating : regular one provided by the builder is Brivis 3 star, which cannot have zoning and upgrade to SP series - i.e. 4, 5 or 6 star would be required. Zone upgrade option: Zone Option 1 - Provide Brivis Zone Plus Heating System 2 zones to Single Storey $1,604.00 Includes 1No. Networker Controller (NC6) in lieu of standard programmable controller (included in upgrade to heating unit), 1No.temperature sensor, 2No. zone motors. Zone Option 2 - Provide Brivis Zone Plus Heating System 3 zones to Single Storey $2,223.00 Includes 1No. Networker Controller (NC6) in lieu of standard programmable controller (included in upgrade to heating unit), 2No.temperature sensors, 3No. zone motors. Zone Option 3 - Provide Brivis Zone Plus Heating System 4 zones to Single Storey $2,372.00 Includes 1No. Networker Controller (NC6) in lieu of standard programmable controller (included in upgrade to heating unit), 2No.temperature sensors, 3No. zone motors & 1No. 506 module Unit options: Unit Option 1 - Upgrade heating unit from a Brivis CC3 to SP4 (3 Star to 4 Star) unit, includes upgrade to networker controller in lieu of programmable $959.00 Unit Option 2 - Upgrade heating unit from a Brivis CC3 to SP5 (3 Star to 5 Star) unit, includes upgrade to networker controller in lieu of programmable $1,483.00 Unit Option 3 - Upgrade heating unit from a Brivis CC3 to SP6 (3 Star to 6 Star) unit, includes upgrade to networker controller in lieu of programmable $1,834.00 Evaporative cooling : Brivis Contour L66 unit to 8 points. $7,808.00 Refrigerated air conditioning: 14.80 kW (Nominal cooling capacity) single phase Brivis refrigerated air conditioning to 9 points including upgrade of the heating unit from the Brivis Compact Classic to 5 Star unit - $15,135 (so this includes Unit Option 2, which is builders $1,483.00) I believe refrigerated air conditioning would be reverse cycle, so can be used for both cooling and heating. Yes, included 5 star gas heater would be another option for heating. So the point is, if I upgrade to 5 star gas heater ( $1,483.00) and no zoning + Evaporative cooling ( $7,808.00), it would be $9291 With Refrigerated cooling (5 star gas heater and no zoning), it would be $15,135 Difference is - $5,844 Please note that most of the time around the year, only living and master bed would be used. Also, I will be using more of heating than cooling ( I can bear most of the summer heat, not the cold weather in the peak winter ). I am aware that refrigerative cooling is a closed system and for Evaporative cooling to work, there should be few windows opened. My confusions are, 1) Is it worth upgrading to Refrigerated cooling by paying $5,844 2) Is it worth to upgrade to Brivis Zone Plus in a single storey 29 squares home by paying $1,604.00 for 2 zones. Read somewhere that zoning may not effective in single storey house and anytime at least 6 vents should be open for smooth working of the Gas heating. 3) Is it beneficial to upgrade the gas heating unit to 6 star ( $1,834.00 ) with no zoning and then have Evaporative cooling. It is will be very helpful if you could provide your suggestions based on your experience. Thanks, Shi I have the same question.. Can I ask what did u land up getting done? I am confused between: Electric heating and electric cooling vs gas heating and refrigerated cooling vs gas heating and split air con. Evap cooling is simply out of question for me. I am also confused because this is mostly going to be an Investment property with potential chances of me living in it (not a 100% sure yet). What do most renters prefer? and what is best cost wise and effectiveness? Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 18Sep 18, 2020 3:33 pm Hi RC56, If you can work hard to just go with invididual split systems these are much better than most other heating/cooling options due to:
Only negatives I can think of is where to position the outdoor unit. Some people don't like the look of them, but to me they're not that big anyhow and the noise is minimal. --------------------------------------------------------------------- Check our Homeone build blog here Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 19Sep 18, 2020 4:26 pm Ok . Right. Something to think of. Also it will be a rental property initially so will have to think how many split to install. One in living and one in master I guess. I am only concerned of the efficiency of the split. Builder if offering us the cooling as an add on in the same vents as gas heating. So the number of vents will be same as the heating vents. Gas heating will be there regardless . Add-on will be for cooling only. Therefore Cost wise the add-on cooling works out $4000 more than getting 2 split system plus their installation charges. So I m Thinking is it worth getting add-on cooling instead of split.. for just an extra 4k.. this amount divided by 30 years of loan is not a lot. Re: Evaporative Cooling / Gas heating vs Refrigerated coolin 20Sep 18, 2020 4:28 pm We took credit for gas heating and evaporative cooling and post handover went with 16kw daikin premium and 7 zones with izone nexus controller, sensors and open wifi bridge so that everything can be controlled on mobile over wifi and 4G.. 4 10824 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3667 |
