Browse Forums Building A New House 1 Nov 19, 2019 10:00 pm This is our first build with Coral. We have some acreage on the way to Tambourine. So after nearly 3 months our date has been set to sign our contract. After reading everyone’s threads for the last couple of months, it’s not uncommon for Coral to take FOREVER to do the paperwork. Our finance broker is mortified. We have taken the Bahama 50 and modified every room in the house I think. Hopefully they draw up the contract properly as the tender letter was incorrect. Anyone else have problems with their contracts being incorrect? Re: Coral Bahama 50 - heavily modified 2Nov 20, 2019 6:12 am Industry wide, most new home buyers remain blissfully unaware after contract signing or discover issues too late. Plenty of examples to be found on Homeone. Pre contract signing accounting (with mistakes invariably in the builder's favour) also needs close examination as well as looking for unfair contract clauses and 'hidden' but increasingly common "Performance Solutions". Try your utmost to avoid variations and their associated charges. Don't focus on aesthetics at the expense of functional practicality. Few houses are designed for future trends and emerging or already established demographics. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Coral Bahama 50 - heavily modified 3Nov 20, 2019 6:58 am Go through every single line item in the contract and check it’s what you have specified and is the correct $ amount. In addition to the paper copy and PDF of the contract Ask for a data file to assist you in this checking and save time. The builder can generate this. Make sure everything is to be built to the standards referenced in the National Construction Code, not alternative “performance solutions” proposed by the builder which you have no ability to check are appropriate. Re: Coral Bahama 50 - heavily modified 4Nov 23, 2019 7:24 am SaveH2O Industry wide, most new home buyers remain blissfully unaware after contract signing or discover issues too late. Plenty of examples to be found on Homeone. Pre contract signing accounting (with mistakes invariably in the builder's favour) also needs close examination as well as looking for unfair contract clauses and 'hidden' but increasingly common "Performance Solutions". Try your utmost to avoid variations and their associated charges. Don't focus on aesthetics at the expense of functional practicality. Few houses are designed for future trends and emerging or already established demographics. Thanks saveH2o. We’ll be sure to go through everything with a fine tooth comb! Re: Coral Bahama 50 - heavily modified 5Nov 23, 2019 7:26 am Norfolk Go through every single line item in the contract and check it’s what you have specified and is the correct $ amount. In addition to the paper copy and PDF of the contract Ask for a data file to assist you in this checking and save time. The builder can generate this. Make sure everything is to be built to the standards referenced in the National Construction Code, not alternative “performance solutions” proposed by the builder which you have no ability to check are appropriate. Thanks Norfolk, the contract signing was a dogs breakfast, with so many mistakes. Doesn’t give you much hope of them getting the build correct. Re: Coral Bahama 50 - heavily modified 6Nov 23, 2019 8:25 am Bonybon5902 Tthe contract signing was a dogs breakfast, with so many mistakes. Doesn’t give you much hope of them getting the build correct. This isn't unusual and is industry wide. A lot of new home buyers don't have their contract checked . The contract and build quality are separate. The build quality will depend heavily on the professionalism of the SS but many working for other project builders have up to 20 and sometimes more constructions under their control at the one time. This doesn't apply to all builders and I don't know if Coral follows this approach but it is a question worth asking. Just remember that several trades build a house and it is impossible for the ss to be expert at them all, the reason many new home buyers contract an experienced building consultant to do vital stage inspections. Having a competent CCTV cam inspection of the stormwater and drain (sewer) pipes done by an independent plumber to check for foreign objects, pipe damage and slope pre final inspection is wise. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13771 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4342 |
