Browse Forums Building A New House 1 Nov 19, 2019 11:00 pm This is our first build with Coral. We have some acreage on the way to Tambourine. So after nearly 3 months our date has been set to sign our contract. After reading everyone’s threads for the last couple of months, it’s not uncommon for Coral to take FOREVER to do the paperwork. Our finance broker is mortified. We have taken the Bahama 50 and modified every room in the house I think. Hopefully they draw up the contract properly as the tender letter was incorrect. Anyone else have problems with their contracts being incorrect? Re: Coral Bahama 50 - heavily modified 2Nov 20, 2019 7:12 am Industry wide, most new home buyers remain blissfully unaware after contract signing or discover issues too late. Plenty of examples to be found on Homeone. Pre contract signing accounting (with mistakes invariably in the builder's favour) also needs close examination as well as looking for unfair contract clauses and 'hidden' but increasingly common "Performance Solutions". Try your utmost to avoid variations and their associated charges. Don't focus on aesthetics at the expense of functional practicality. Few houses are designed for future trends and emerging or already established demographics. 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au Re: Coral Bahama 50 - heavily modified 3Nov 20, 2019 7:58 am Go through every single line item in the contract and check it’s what you have specified and is the correct $ amount. In addition to the paper copy and PDF of the contract Ask for a data file to assist you in this checking and save time. The builder can generate this. Make sure everything is to be built to the standards referenced in the National Construction Code, not alternative “performance solutions” proposed by the builder which you have no ability to check are appropriate. Re: Coral Bahama 50 - heavily modified 4Nov 23, 2019 8:24 am ![]() Industry wide, most new home buyers remain blissfully unaware after contract signing or discover issues too late. Plenty of examples to be found on Homeone. Pre contract signing accounting (with mistakes invariably in the builder's favour) also needs close examination as well as looking for unfair contract clauses and 'hidden' but increasingly common "Performance Solutions". Try your utmost to avoid variations and their associated charges. Don't focus on aesthetics at the expense of functional practicality. Few houses are designed for future trends and emerging or already established demographics. Thanks saveH2o. We’ll be sure to go through everything with a fine tooth comb! Re: Coral Bahama 50 - heavily modified 5Nov 23, 2019 8:26 am ![]() Go through every single line item in the contract and check it’s what you have specified and is the correct $ amount. In addition to the paper copy and PDF of the contract Ask for a data file to assist you in this checking and save time. The builder can generate this. Make sure everything is to be built to the standards referenced in the National Construction Code, not alternative “performance solutions” proposed by the builder which you have no ability to check are appropriate. Thanks Norfolk, the contract signing was a dogs breakfast, with so many mistakes. Doesn’t give you much hope of them getting the build correct. Re: Coral Bahama 50 - heavily modified 6Nov 23, 2019 9:25 am ![]() Tthe contract signing was a dogs breakfast, with so many mistakes. Doesn’t give you much hope of them getting the build correct. This isn't unusual and is industry wide. A lot of new home buyers don't have their contract checked ![]() The contract and build quality are separate. The build quality will depend heavily on the professionalism of the SS but many working for other project builders have up to 20 and sometimes more constructions under their control at the one time. This doesn't apply to all builders and I don't know if Coral follows this approach but it is a question worth asking. Just remember that several trades build a house and it is impossible for the ss to be expert at them all, the reason many new home buyers contract an experienced building consultant to do vital stage inspections. Having a competent CCTV cam inspection of the stormwater and drain (sewer) pipes done by an independent plumber to check for foreign objects, pipe damage and slope pre final inspection is wise. 3 in 1 Supadiverta. 0.75mm filter. No downpipes diverted. Can delete overflow pipe. Cleaner Neater Cheaper Supa Gutter Pumper. An inexpensive gutter overflow solution. https://www.aquatrek.net.au Wow! Even more things to consider, thank you.. I do agree with the sliding door in the lounge room that will be quite the thoroughfare, very good point. At the moment I… 5 1289 |
