Browse Forums Building A New House 1 Nov 12, 2019 7:51 am Hi All,
The home 30 sq that I like is just fitting in the lot of land I have. The builder says they will need to trim the eaves of the home from the back (highlighted) if I need this home on my land. I can otherwise choose a smaller 28sq home which will fit including standard eaves. Is there a issue with the home with smaller eves at the back. Will it cause a big difference ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Trim the eaves or get a smaller home 2Nov 12, 2019 8:34 am Depends on your location and orientation. Eaves are definitely beneficial for keeping the sun off your walls and keeping windows shaded for longer periods of time. What is your location and where is north? 7 3006 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5869 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7856 |
