Browse Forums Building A New House 1 Nov 04, 2019 7:56 am Good morning, I am applying to Council to install a driveway for my newly completed forever home. I am positioned on the outside of the L corner and there is a comment that the driveway. 5. Conditions 5.1 Prohibited location of driveways Driveways should not be located within six metres offset from the tangent point of the kerb return, unless approval from Council is given. Some properties may have individual constraints that may apply. https://www.campbelltown.nsw.gov.au/fil ... itions.pdf Below shows the approx location of driveway which formed part of the builders submission. I had heard that Council will provide some funding credits when your crossover replaces part of the footpath and the concrete retains plain colour, whilst the driveway behinds the boundary can be coloured. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am also looking for some guidance to have a platform extending from the garage door, back ~4.2m (1m@10% then 3.2m @ 2.5% to allow the vehicles to be on a very minimal gradient, then drop off the the next 2.3-2.5m to the footpath. Height between footpath and driveway height is 1.04m over 7m. Below is what i am thinking would achieve what i am looking for. Thoughts please and thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Driveway regulation interpretation and advice needed ple 2Nov 04, 2019 8:01 am If you ask nicely council, engineers will be more than happy to assist you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Driveway regulation interpretation and advice needed ple 4Jul 21, 2022 8:23 pm Hi GLO, We are in a similar position wanting to install a driveway on a corner block with the proposed driveway 5.4m to the tangent point. How did you go with Campbelltown Council? We are in Hills Shire so may be a slightly different team but guidelines are in line with the Aust Standard. I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9985 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18561 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6966 |
