Hi,
Just registered and currently building. At the moment, I'm trying to work out how to position all electricals, and wondering if there were any tips on where to position outlets in rooms, e.g. in the corners, under windows etc ...
Trevor
Browse Forums Building A New House 1 Sep 24, 2008 11:42 pm Hi,
Just registered and currently building. At the moment, I'm trying to work out how to position all electricals, and wondering if there were any tips on where to position outlets in rooms, e.g. in the corners, under windows etc ... Trevor Re: GPO & Data Outlets 2Sep 25, 2008 12:06 am I'm going through the same process at the moment. My suggestion is to place furniture and then place power points. Try different furniture positions to ensure that the power points are in the right location.
For data points, go for more as I think they will be progressively more useful in the future. For instance in kids bedrooms place a data point behind the bed and another where the desk will go. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: GPO & Data Outlets 3Sep 25, 2008 7:15 am At the moment, since it's only frames up, difficult to imagine where furniture will be, and also haven't totally decided what'll be in the rooms.
I've only gathered two tips in general placement for both at the moment: Place GPO's at the extremities to ensure maximum cable runs around the house. Place GPO's next to all data outlets. So based on that, living areas is done, but rooms not done. Re: GPO & Data Outlets 4Sep 25, 2008 7:40 am When I said place furniture, I meant on the plans.
Certainly make sure the data points are next to a power point. I'm aiming for roughly one double data point for every second power point. Demolition August 2009, Construction Started September 2009, Completed December 2010 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20669 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13862 |
