Hello everyone. I was hoping to get some feedback on my proposed pool and house position. I have a sewer line at the back of the block, thus limiting how far back I can set the pool. I have the option to move the house to the higher side by another 500MM (left looking on the elevation picture) but am worried that because of the 300MM or so cut the builder is doing on that side, moving the house closer to the boundary would mean I need to build a small retaining wall.
The drop in levels from one side to the other side of the entire block width is about 600MM. The builder will be doing a small cut and a fill.
My main question is, do you think the 1749MM distance between the proposed pool fence and the alfresco stairs is sufficient for comfortable access? Is it too close to the house? Or should I bite the bullet and move the house closer to the boundary (build a retaining wall) and give me an extra 500MM.
Also, is the size of the proposed coping around the pool adequate?
Appreciate your help!
