Browse Forums Building A New House 1 Sep 22, 2019 5:07 pm Hi, I am in the process of planning for my new project home. I am looking at Options for having sunhoods supplied and fitted for my new home. I have found a supplier which has a wide range of sunhoods which includes the sun Hoods and the fixing hardware. One of the important components in the construction process when installing the sun Hoods, or any other external accessory fix through the external wall, is the wet sealing process. The sun Hoods need to be wet sealed full stop does anybody have any trades manuals contain any instructions on how to Wet Seal and external fittings to an external wall? I am building in Queensland. This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10344 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11561 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5193 |
