Browse Forums Building A New House 1 Sep 19, 2019 9:32 pm Hi all, Just seeking some advice on our slab that was poured today. It was raining this morning was the poor was completed which was a slight concern. There are two exposed reo bars completely exposed. I understand that exposed reo isn't good although I'm not sure whether these are part of the structure or just there for the formwork or something? A few of the edges are poorly finished, not smooth and have small chunks missing. A couple of the edges aren't exactly straight although I suppose the bricks will be laid around the outside of the slab. Should this be raised with the builder or will they return to fix this? In WA by the way. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab just poured 2Sep 19, 2019 9:34 pm Nothing wrong with any of that, they are used as pegs to hold the form work in place Re: Slab just poured 4Sep 20, 2019 10:56 am Stephec1 At a glance I would have the slab inspected by an Engineer. my2c 1. Placing concrete in rain before the set can effect its strength, durability,etc Too much Rain when placing Concrete 2. Horizontal exposed bars are structural, edge vertical exposed bars are pins for formwork 3. I'd grab a large sample of the hardened concrete that's been discharge from the truck, left on site. etc 4. More info required Size of the House Do you have the site report, engineering Slab and footing details? Was the slab reinforcement inspected before the pour? Compromised footings/slabs are the start of building Woes..be prepared Forewarned is forearmed Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab just poured 5Sep 20, 2019 12:09 pm Doozer1905 Do you know what termite treatment they are using? Thanks Doozer, I know it the Termico Management system - treatment to soil, termite blanket at zero lot boundary, perimeter treatment. Not sure on the specific products Re: Slab just poured 6Sep 20, 2019 4:44 pm my house uses Termico, haven't had any issues, though you do have to pay for the yearly inspection to maintain the warranty. Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 2666 Hi all, Trying to workout the minimum stepdown required between slab for my house and the outdoor alfresco area. Garage is 100mm lower than rest of the house and plan was… 0 3663 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 11076 |
