Browse Forums Building A New House 1 Sep 15, 2019 10:08 am Hi, Looking to purchase a parcel of land which has a restrictive covenant from 1935 which says "no building erected on the land should have its roof or exterior walls made from iron or metal". If we buy we would be looking at building a modest modern home with a flat colour bond roof not visible from the street. Going up and down the street there are many other homes using Colour Bond. My question is now in 2019 would Colourbond be seen as an acceptable roof material in light of the covenant? And secondly who would enforce the covenant? Would a building surveyor take issue with us using an unseen Colourbond roof? Re: Restrictive Covenant Roofing Question 2Sep 15, 2019 10:48 am We are building on land that, when newly released 35 yrs ago had a covenant of no metal roofs. Our current design has a Colorbond roof (very visible, pitch is 33degrees). If other houses in the area have metal roofs/walls, I’d say you’d be fine! Re: Restrictive Covenant Roofing Question 3Sep 15, 2019 2:22 pm Did the covenant not have an expiry date? The one relating to our 'estate' expires in another year or two, so only applied for the first 5 years roughly from when the subdivision was released. --------------------------------------------------------------------- Check our Homeone build blog here Re: Restrictive Covenant Roofing Question 4Sep 15, 2019 2:31 pm Good answer from darb74 Most covenants will have expiry date, check your title then ask your lawyer. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I recently hit a snag with my new build with Metricon. On the block I purchased there is an old covenant when the land was subdivided in 1971 that "the exterior walls of… 0 1505 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 754 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 |
