Browse Forums Building A New House 1 Sep 11, 2019 11:09 am We have just completed our build (HIA contract). After our final walk through and the payment of our final progress payment we have been sent a draft invoice for a Final Account for an additional $50,000. Largely this is due to additional piers and beams under the slab but at no point were we told there was going to be an additional cost associated with this and at no point did we sign a variation agreeing to the additional cost. HELP !?!?! What are our rights? Re: Slogged with an unexpected bill at end of build 3Sep 11, 2019 1:10 pm If you have already paid the full contract price the builder is obliged to hand over your house immediately unless the contract somehow says otherwise. Ask the builder to show you the documents with your signature on them authorising the extra $50k of work that they say they did. Or the advising documents they should have sent you as close as possible to the time of the work being done, as per the applicable building law. Ask for their complete orders and invoices, payment records for the works done. They cannot slip in extra costs, real or otherwise, and withhold the house. If they don’t cooperate take the pro forma invoice to your lawyer to sort out.
Re: Slogged with an unexpected bill at end of build 4Sep 11, 2019 1:35 pm luxbuild From what you are saying, it doesn't seem to be inline with Clause 18 of the HIA contract at all. Could it be under a provisional sum? There were provisional amounts allocated to a number of items (piers & beams, bush fire requirements, storm water etc). The builders significantly exceeded the provisions for all of these but didn't give us any indication that this had occurred until they sent us the bill after completion. Re: Slogged with an unexpected bill at end of build 5Sep 11, 2019 5:48 pm FYI HIA Contract says: Clause 20.7 Any adjustment to the contract price for a prime cost item or a provisional sum item is due and payable with the next progress payment, unless a different time is agreed in writing. Clause 21.7 On the owner paying the final progress claim, the builder must give the keys, certificates, warranty documentation and other documents pertaining to the building works to the owner. Re: Slogged with an unexpected bill at end of build 6Sep 11, 2019 6:45 pm Hi Freerange What site works & class footings were you quoted on originally? What was the final Engineering Details supplied eg upgrade from Class A to M, though even then $50K is grossly excessive, do you have photos? More info required etc,etc The builder needs to be more specific with Cost Breakdowns and specifications..NO Signed Variation order? OT, you could have been able to void the contract, before they started if you were aware, unfortunately now it gets messy Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slogged with an unexpected bill at end of build 8Sep 12, 2019 9:55 am StructuralBIMGuy Hi Freerange What site works & class footings were you quoted on originally? What was the final Engineering Details supplied eg upgrade from Class A to M, though even then $50K is grossly excessive, do you have photos? More info required etc,etc The builder needs to be more specific with Cost Breakdowns and specifications..NO Signed Variation order? OT, you could have been able to void the contract, before they started if you were aware, unfortunately now it gets messy Class didn't change (M at start), cost was all underground piering. All we were told at the time was that the engineer changed his mind and wanted additional piers etc under the slab (I think they were screw pilings?). At time of slab we were 'verbally' told the extra cost would be covered by other provisionals. Needless to say, it wasn't! Re: Slogged with an unexpected bill at end of build 9Sep 12, 2019 12:28 pm What does your independent building consultant say about all this? Ru in Vic. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Slogged with an unexpected bill at end of build 10Sep 12, 2019 10:46 pm FreeRange StructuralBIMGuy Hi Freerange What site works & class footings were you quoted on originally? What was the final Engineering Details supplied eg upgrade from Class A to M, though even then $50K is grossly excessive, do you have photos? More info required etc,etc The builder needs to be more specific with Cost Breakdowns and specifications..NO Signed Variation order? OT, you could have been able to void the contract, before they started if you were aware, unfortunately now it gets messy Class didn't change (M at start), cost was all underground piering. All we were told at the time was that the engineer changed his mind and wanted additional piers etc under the slab (I think they were screw pilings?). At time of slab we were 'verbally' told the extra cost would be covered by other provisionals. Needless to say, it wasn't! Why were piers done if it was a "M" ? Class "P" warrants piers. Get hold of the soil test and slab design. Re: Slogged with an unexpected bill at end of build 11Jul 15, 2020 9:41 am FreeRange luxbuild From what you are saying, it doesn't seem to be inline with Clause 18 of the HIA contract at all. Could it be under a provisional sum? There were provisional amounts allocated to a number of items (piers & beams, bush fire requirements, storm water etc). The builders significantly exceeded the provisions for all of these but didn't give us any indication that this had occurred until they sent us the bill after completion. I worked for a large builder and the Provisional Sums were all adjusted at the end of the build. Was all noted in the fine print of the contract, but that amount seems large and they would have been aware if it was well over your PSums allowance. Re: Slogged with an unexpected bill at end of build 12Jul 15, 2020 10:47 am If you are in Victoria then there is protection against this types of claims under DBCA1995 but unless you have a good building consultant you will likely save few hundred dollars only to lose tens of thousands. The common problem is the relationship between builders and engineers opening up opportunity for unnecessary .over engineering at owner's cost Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2137 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3878 |
