Buying land - what to watch out for
Is there anything I need to be aware of? It will be pending finance, but do I need soil tests, or maps showing easements etc?
Appreciate any advice.
It faces north
Yeah, unfortunately worst direction for energy efficiency.
North facing blocks are the least attractive for a home.
Check out http://anewhouse.com.au/2012/02/block-orientation/
Hmm I tend to disagree. It depends.
Facing east with houses built
boundary to boundary u don't get much sun at all, particularly ground floor. And if it's single storey it's even worst.
And window needs to be obscure so that it won't overlook neighbour.
Facing north. Nothing is going to block your sun at the front.
Just your own garage.
Doubke storey u only lose one quarter.
But anyway as I said it depends.
Definitley true if it those long narrow piece of land.
But if its wide.. Then it can be quite good.
bean1969 is looking at a typical volume build design, think of what rooms are at the front of the house. Bedrooms and maybe secondary living spaces. The main living areas where most of the daylight time will be spent (open plan kitchen, living, meals) are usually at the back of the house.
If planning a custom design it is likely the designer will still put main living areas in the back, then use courtyards, clerestory windows etc to get the north light into the back of the house. So yes it can be done, but it’s more costly.
bean1969 we don’t know what your block is like or even where it is, but as you are in a position to buy a vacant block of land, try looking for one that faces rear to north (-ish). I can guarantee you with a southfacing back, your living areas will be cold and dark in winter.
Sure. But assuming If planning a custom design it is likely the designer will still put main living areas in the back, then use courtyards, clerestory windows etc to get the north light into the back of the house. So yes it can be done, but it’s more costly.
As oppose to the initial one line reply.
Which way does it face?
North-North East
bean1969, getting a map of any easements, services etc is certainly a good idea. As you probably know, you can’t build over easements, and services you may have to spend extra to protect them (can’t remember the technical term for this!)
Additionally, Additionally, bean1969, getting a map of any easements, services etc is certainly a good idea. As you probably know, you can’t build over easements, and services you may have to spend extra to protect them (can’t remember the technical term for this!)
Thanks, I will find out about that tomorrow
Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried…
28/04/2024
we are planning to buy a house on the warrigal road, but most of our friends say buying on main roads is not a good idea mainly because 1. constant traffic noise 2.…
16/07/2023
4
Thanks mate, this helped a lot. Managed to get it back in.
