Browse Forums Building A New House 1 Sep 22, 2008 6:54 pm Hi
What is the normal double storey home height ? We went to our council for a planning permit - the new height restriction for double storey home is 7.5m. We are 8m - so have to apply for a permit that may take 2 months - So yet another hurdle in this building saga. As per the rules for our area:- We cannot cover more than 40% of the land We have to build a home that is at least 26 squares. The height has to be under 7.5 m They are recommending a town planner to help prepare why we exceed the height and justify why they have to accept it - Is this normal? Anyone had to do something similar - any experiences would love to hear Regards beegee Re: Heigh of double storey AND councils 2Sep 22, 2008 9:41 pm beegeers We cannot cover more than 40% of the land that sounds a bit strange, normally you have to have a certain amount of area that must be open air space; ours is 25% of the property - must be open air space (hence you cant build on it) this does include both front and back lawns. but 40% sounds a bit strict, but i am sure it does differ from council to state. certainly not going to hurt to ask them again. as for the height 7.5-8m sounds like it includes the roof, so your pitch would have to accommodate that to suit the requirements; however there are always exceptions. -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Heigh of double storey AND councils 3Sep 23, 2008 10:47 am Two story houses can be many heights.
Our council in Sydney is much like yours. We are not allowed to cover more than 50% of our land with livable space including garage, veranda, etc and floorspace on all floors. Our council also has an overall height restriction of 9 metres for two story houses, and a plate height limit of 7.5 metres. The plate height is from ground level to the bottom of the eaves. In our case most of the project homes fit this criteria, but we are doing a custom build so it was easy to adjust roof pitch etc to get the correct height. I doubt our council would have approved anything higher than the restrictions. Greg Re: Heigh of double storey AND councils 4Sep 23, 2008 10:53 am Don't forget with height restrictions the setback actually curves in as you go up and the higher you go the setback between the house and the boundary to your neighbour increases as well.
good luck smeags Re: Heigh of double storey AND councils 5Sep 23, 2008 11:52 am smeagol Don't forget with height restrictions the setback actually curves in as you go up and the higher you go the setback between the house and the boundary to your neighbour increases as well. good luck smeags In our case a single story has to be at least 900 mm away from the side boundary, and a 2 story has to be 1.5 metres. Is that what you meant? There are no restrictions for front and rear setbacks in regards to height in my council. Greg Re: Heigh of double storey AND councils 6Sep 23, 2008 3:31 pm Yes, our council is also quite strict. We can only build max 40% of our land. But there is no minimum house size. What happens to those in your council with small land and they cannot fulfil both the criteria of 40% and 26 squares? Re: Heigh of double storey AND councils 7Sep 24, 2008 11:25 am Hi
We went to the council - Looks like a neighbor down the street who is building a Dennis Family Home has got a dispensation for height - reason dispensation was issued because other houses in the area exceed the height of 7.5m If that is the case why does the council insist on this rule ? So now we have to wait for another 8+ weeks..... Building Saaga Quote: What happens to those in your council with small land and they cannot fulfill both the criteria of 40% and 26 squares? I have wondered too - We are building in a a new sub division which has 14 blocks and the smallest 700sqm - So guess it is OK. Thanks beegee Re: Heigh of double storey AND councils 8Sep 26, 2008 4:07 pm Hey Beegers
I just learnt this the hard way but i thought i'd share it with you and everyone here. I left dealing with the council to my builder and they sucked and it took 7 weeks. I spoke to my brother about it and asked him how he got around it when he built his house, he said he took it down personally and spoke to the people there, lucky for him he only needed a dispensation for front setbacks and got his neighbours to sign it plus all the required documents and they did it on the spot for him. good luck mate smeags. (Australian who lived in San Diego for 5 years Re: Heigh of double storey AND councils 9Sep 26, 2008 10:13 pm Hi smeagol
Thanks for that info We just went and submitted our permit application. As ur brother did we have attached relevant documentation images etc etc The council person said we would know in 2 weeks who would handle our file After that we would know how long the process is......... All this for 1/2 a metre height increase and we did not build prior to 2006..... Thanks beegee I recently hit a snag with my new build with Metricon. On the block I purchased there is an old covenant when the land was subdivided in 1971 that "the exterior walls of… 0 1505 1 4581 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9952 |
