Browse Forums Building A New House 1 Jul 29, 2019 11:34 am Hello, I am about to start working on plans for a home I am building in WA, can anybody point me in the right direct for information on building against the boundary line and the regulations? My block is a corner block, and I am hoping (but skeptical) that I can build right up to the fenceline along the side where there is no other property. The reason I ask is because the block is quite small, (not the smallest block however) at 385sqm, and I want to maximise the size of the property for resale value. Thanks Re: Building on boundary line in WA 2Jul 29, 2019 11:43 am Google Residential Design Codes WA, this should take you to the department of Planning and it's there. There is a high chance that there should be a DAP (detailed area plan) on your block as well, if that's the case, ring the local council and ask for it. Re: Building on boundary line in WA 3Jul 29, 2019 11:48 am Ok thanks, the site is incredibly detailed I wouldnt even know where to begin to look for a DAP on my specific block, but I'll read through the design code pdf that is available. Re: Building on boundary line in WA 4Jul 30, 2019 1:20 pm The setback to the secondary street is required to be 1500mm, Walls can be built up to the boundary on the side or rear boundary dependent on your zoning - but not to the street boundary. I am a residential building designer. Let me know if you need any other help, Re: Building on boundary line in WA 5Jul 30, 2019 1:26 pm Ah bugger I thought as much. Good thing I have allowed for it by making the rooms on that side of the home bigger, so I guess they can be cut back. Thank you so much for the information In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7077 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17172 Hello, We are about to build and the plans show a part of the exterior wall is being built on top of a limestone retaining wall. Does this mean the retaining wall will… 0 6968 |
