Browse Forums Building A New House 1 Jul 23, 2019 11:20 pm Hi, I will have the builder put up a standard bath tub 1650mm. I checked there are jacuzzi / jet spas of same length 1650mm. My builder is charging arms and length to install that, while I can buy it much cheaper of my own. Can anyone suggest if I can retrofit the same? As an alternate, I also read about some artciles where I can convert the existing bath by adding jets into it. Is that really doable? 3 3565 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15812 |
