Browse Forums Building A New House Re: Gutter on top of brick wall 2Jul 22, 2019 1:40 pm Hi, Yes this is quite a common detail used for "Built to boundary" walls. Is this where it is being used? Re: Gutter on top of brick wall 4Jul 22, 2019 2:01 pm There is typically a metal flashing used to cap the brickwork and cavity. This prevents water entering the brickwork and cavity. Below is a link showing the detail (apologies it's small). https://www.google.com/url?sa=i&source= ... 4201888870 It's also possible to have the guttering overhang the brickwork however you will need to consider your setbacks ect. Hope this helps! Re: Gutter on top of brick wall 5Jul 22, 2019 2:48 pm The gutter's slope or lack of must also be factored. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Gutter on top of brick wall 6Jul 22, 2019 4:32 pm Raj123 Hi, Yes, it is on the boundary wall. Would there be possible maintenance issues if water overflows and goes into wall cavities?? Would you know how to prevent this issue? Thanks for your help. You can also have a box gutter which sits on the inside but a lot of builders dont like them as if they arent installed correctly they tend to overflow and leak, but if installed correctly they are fantastic Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4932 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8974 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2539 |
