Browse Forums Building A New House 1 Jul 16, 2019 9:27 am Has anyone found a “slim” awning window opener? I believe the standard with our windows will be Whitco winders which seem quiet chunky (off to see windows on Friday). Because we have weatherboard, our reveal is 80mm and builder is saying this will leave us with about 65mm internally. The problem is we want plantation shutters which need 65mm clearance for the blades. Even if we get the winders behind the midrails (which need 20mm clearance) I think the Whitco might be too deep. Push handle won’t work as we also need flyscreens. So hoping someone has found a narrow/slim winder? The other idea (which I need to talk to builder about) is to set a plain architrave flush with the reveal instead of having the stepdown/quirk) which should give us a bit extra depth..... Re: Awning window openers for use with plantation shutters? 2Jul 16, 2019 3:39 pm They probably cost $$$, but I've seen powered ones which would mean the switch could be on the wall next to or under the entire frame … but then it's not exactly rocket surgery, so can't be that expensive in the context of the cost of building a house? 4 14131 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 2981 Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11561 |
