Finally got this installed. Excited
What are these GPO and smart light switch? ----installed !!!
See this video from 22 second to 28 second, can anyone tell me what are the powerpoint and light switch?
Clipsal Iconic https://www.clipsal.com/iconicathome
Similar SAA approved outlets at 1/10th of Iconic pricing:
https://www.aliexpress.com/item/32792694818.html
Bluetooth enabled switch is not a good idea either due to limitation on the number of BLE devices within the same area, Wi-Fi switches would be much better option.
http://www.ctec.com.au and are probably the best looking wifi switches available at the moment (still plenty of room for improvement though). They cost around the $120 mark for a 1 gang switch up to $145ish for a 3 gang.
Do not buy any electrical gear from aliexpress, even just from the pictures you can see the switches don't even sit in the fitting properly, just like Arlec or Deta from Bunnings. Just terrible quality and you have a high risk of faulty straight out of the box with nowhere to return it.
The switches are CTEC Do not buy any electrical gear from aliexpress, even just from the pictures you can see the switches don't even sit in the fitting properly, just like Arlec or Deta from Bunnings. Just terrible quality and you have a high risk of faulty straight out of the box with nowhere to return it.
Aliexpress I quoted above were just as an example, Alibaba provides much more options.
But there were not pics over there where switches sit in the fitting, so I am not sure where do you see what they are not fitting properly.
The switches are CTEC http://www.ctec.com.au and are probably the best looking wifi switches available at the moment (still plenty of room for improvement though). They cost around the $120 mark for a 1 gang switch up to $145ish for a 3 gang.
Thanks, just found it. https://www.facebook.com/CtecSmartLightSwitch/ looks pretty good and we might go for this.
Yes, NEVER buy electrical products from overseas, and even I avoid buying from eBay.
Cheers
Thanks, just checked with an electrician and confirmed it is Clipsal Iconic range.
what's your thoughts?
Finally got this installed !!!
Is this Ctec switches?
Yes
Yes mate, I agree they are the best looking.
Looking good. I believe you upgraded your existing switches to CTEC. Did your house has neutral line running thru the switches? I am building with a volume builder and I have no idea how the wiring is done. I am planning to upgrade the switches on few places after handover.
Yes I have got neutral wire. You can request neutral wire from your builder and I think they can do it. Do the upgrade afterwards otherwise the builder will charge more. Also don't go for the cheap crap from eBay, I had some bad experience with those ones and finally dropped them in the bin.
Too late ask the builder as they already started the painting. I am hoping they have done neutral line. But not sure. Thanks anyways
Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about…
3/03/2024
5
We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we…
