Fire alarm by Clarendon Homes
Clarendon built my home in 2015.
We have two fire alarms in a single level home.
They started chirping today !
I opened the cover and got the shock of my life (use with pun) when I discovered that the alarm was not hard wired. All it had was the usual 9 V battery.
For the last four years I had been thinking that both the alarms are hardwired. Even the cover of the alarm has the words “A.C. power”written on it.
Can anyone confirm if Clarendon hardwire their alarms ....
should this thing be in the contract, if yes, where should I look ?
Thanks you
They typically chirp to let you know to replace the battery even if they are hard wired.
Here’s a pic of one of them. No wires that I can see ...
As others have mentioned the chirping noise is to alert you that the batteries have lost power and need replacing.
We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is…
2/08/2023
Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support…
13/08/2023
21
Not back peddling at all. You seem to have issues with comprehension my friend. Guy fcked up, he's considering being dishonest with his bank and hiding it. It will end…
