Browse Forums Building A New House 1 Jul 03, 2019 8:31 pm Hi Guys, If someone can suggest the vendors available in Adelaide who can do the left over works post house build handover. I am looking for someone who can do following and I prefer one stop shop or some vendor who does most of the following things - Stormwater/ Rainwater/ Detention Tank - Flooring ( Tiles/ Carpet/ timber laminate) - Driveway ( concreting/ paving ) - Fencing/ retaining wall - LED Downlights - Aircon - Blinds -Landscaping - Letter Box - Tv Antenna Thank you Your house should come in "as new" condition. It should be clean, and without stains 1 4550 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7743 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3141 |
