Browse Forums Building A New House Re: New Developer Land - What is the PVC pipe sticking out 2Jul 01, 2019 4:06 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: New Developer Land - What is the PVC pipe sticking out 4Jul 01, 2019 5:30 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: New Developer Land - What is the PVC pipe sticking out 7Jul 04, 2019 7:38 pm Not always, the sewer easement is usually at the rear and has a round pit. The stormwater easement usually has a square pit. If your storm water point of discharge is at the front of the block then the stormwater easement should be at the front.They can be in the same easement as well. If you check your land title you will be able to see where the easements are. Re: New Developer Land - What is the PVC pipe sticking out 8Jul 05, 2019 9:15 am Thanks. I was actually just referring to 'your' photo there, as that pit in the photo looks like a sewer pit around here. It just seemed unusual to me that the stormwater point would be directly adjacent to a sewer pit, which gave me a bit of confusion for minute and why I asked. All good though. I have checked our LPOD and sewer and I know we have sewer to the rear and stormwater to the front. Thanks for your help, it has cleared up my query. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7314 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4857 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 843 |
