Browse Forums Building A New House 1 Jun 27, 2019 3:26 pm I have 2 mystery pipes that have been left behind after our build This is in the middle where I want to have lawn at the back. It looks like some sort of sewer vent, or maybe just an access cover. can I cut if off and put a fixed cap below the surface?? Or do I need to relocate further along the line Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This one is at the front. The pipe comes under the footpath and looks like it has been bent up. Looks like an old gas or water pipe, and doesn't look capped. I assume it is OK to cut it off below the surface? maybe I will drill a small hole first to see that nothing escapes?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Mystery pipes after build 2Jun 27, 2019 5:31 pm Not sure about your second one but the first one is a sewer rodding point ( basically an access point if the sewer is blocked sometime in the future) You can cut this off at ground level and buy a flat cap to go over the top from bunnings for a few dollars Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Mystery pipes after build 3Jun 28, 2019 4:11 pm Thanks, I'll do that. A bit annoyed that they put it in the middle of the lawn rather than near the fence I cut off the second one with an angle grinder (after first drilling a small hole) and all good 4 5116 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10815 |
