Browse Forums Building A New House 1 May 31, 2019 9:02 pm Hi All, we are researching to build a two storey home is Brisbane. We found a block with very steep block. See attached. Would appriciate suggestions: - Any good builder - Hidden cost - Any good design Site: “S” in accordance with AS2870-2011 Wind: “N3” in accordance with AS4055-2012 ---------------------- This site contains significant trees which may affect the foundations of the proposed residence. Remove existing trees and tree roots/material over the proposed building area. Any soft or loose material that does not respond to compaction should be excavated to achieve a firm working base. Fill holes with suitable fill compacted in 150mm (maximum) layers. • This site contained significant trees that have been recently removed. The builder is to ensure all tree roots/material over the proposed building area has been removed. Any soft or loose material that does not respond to compaction should be excavated to achieve a firm working base. Fill holes with suitable fill compacted in 150mm (maximum) layers. • An engineer designed footing system in accordance with AS2870 2011 is recommended for this site taking into consideration the effect of the removed and existing trees in relation to the final house siting. • Demolition of the previously existing structure is likely to leave isolated pockets of fill and or disturbed ground conditions. Where there is local disturbance the proposed foundations must extend a minimum of 100mm below the level of disturbance into either of the naturally occurring materials as identified in Section 2 of this report. Note alternatively the disturbed material may be controlled and subsequently adopted as a founding material (refer definitions on controlled FILL). Re: Very Steep Block Brisbane - New home Construction 3Jun 01, 2019 2:54 pm G’day BrisbaneTechno, I am a building designer and have a little firm in inner Brisbane. I specialise in the delivery in these types of projects. Broadly, the key thing we need to establish first would be your budget, from there we can determine an appropriate building methodology based on your wish list. For example, terracing some of the lot, maybe a split level design, or a one level home with a post and bearer type circumstance. Once we establish this with can PC a cost for the construction of the home and assume a SQM rate, we are typically within 5% either way for an estimate and this allows us to work backward to give us a SQM to work to based on specification (ie wanting a modern home, traditional etc). I have a few example I could share. If you’re interested, feel free to shoot me an email on here and I can offer an onsite consultation. Re: Very Steep Block Brisbane - New home Construction 4Jun 01, 2019 3:15 pm Thanks for your reply. Happy to discuss further. FSBD G’day BrisbaneTechno, I am a building designer and have a little firm in inner Brisbane. I specialise in the delivery in these types of projects. Broadly, the key thing we need to establish first would be your budget, from there we can determine an appropriate building methodology based on your wish list. For example, terracing some of the lot, maybe a split level design, or a one level home with a post and bearer type circumstance. Once we establish this with can PC a cost for the construction of the home and assume a SQM rate, we are typically within 5% either way for an estimate and this allows us to work backward to give us a SQM to work to based on specification (ie wanting a modern home, traditional etc). I have a few example I could share. If you’re interested, feel free to shoot me an email on here and I can offer an onsite consultation. Re: Very Steep Block Brisbane - New home Construction 5Jun 02, 2019 6:32 am Hi brisbanetechno Here you might find this useful Slab and formwork costs sloping block Make sure you get all the Engineering data/proofs and costs upfront, optimise and compare the costs forewarned is forearmed HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thank you so much Simeon and I ll definitely reach out to Brad. Regards Kishan 99 360682 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11997 I can help you with all that, you can PM me with details if you wish 3 5969 |
