Browse Forums Building A New House 1 May 29, 2019 8:30 am In the course of our build, the minister for war and finance decided that we should incorporate an operable wall in our rumpus room to provide an occasional bedroom. Just wondering if anyone knows where I can source ceiling mount track and carriages? I have looked at a couple of companies but they insist on supplying a full kit, with a price tag of 5k for a 3.2m opening. I have the necessary tooling and skills to make panels (and a desire to do so), if I can only locate a supplier of suitable track. Thanks in advance Re: Ceiling mount tracks for operable walls 2May 29, 2019 10:01 am You could try Brio: https://brio.com.au/products/ They do tracks and individual components for tracks at various weight ratings and with lots of different functions. They can put you in touch with a distributor local to you who can order for you. I sell them where I work and you can usually cobble together a track set for most applications if their standard sets dont cut it. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8319 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6066 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11124 |
