Browse Forums Building A New House 1 May 24, 2019 4:05 pm Hi there, I just had a double colorbond gate installed. Some cement were poured around the latches to act as an anchor because the latches do not reach the ground. This did not even last a day. The wind blew the gate open. The gate was done at this height because of my concrete path around the house (which is about 15cm high) and I'm planning to add some soil or gravel to level the ground to the concrete pathway afterwards. Is there a better solution to hold the gates until the ground is levelled? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12145 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9099 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6711 |
