Browse Forums Building A New House Re: Am I being too fussy?? 3May 17, 2019 11:28 am darb74 Howdy, Re: the split in the window 'reveal' we've got a couple I have noticed on our build. The main one one the sliding door I notice they used liquid nails and screwed it together tighter. I'm not worried about it as I know it will be painted over and it's not a structural item. To fix the issue would likely involved removing the entire window/door and my concern always is do they cause more damage trying to fix it?! With the architraves not aligning perfectly, I think this should be fixed up and probably will be by simply sanding or planing back? But not sure TBH. Overall I think these issues are very minor, and if you feel the builder has generally done ok with everything else so far I would consider going easy on them. The way I look at it, is you need to pick your battles. If you do ask for certain things later to be fixed always remind them of the mis-aligned arch's you didn't hassle them about! Thanks for your input and I’m glad to know it’s common so I think I’ll just leave it and keep a eye on it if they liquid nail and screw it in nice and tight I’ll be happy with that! Our ss has been fantastic so I’m trying to be easy on him haha we are just really fussy but he has let us do so much like insulate the internal walls ourself , install a gas line in the alfresco , even knock down a gyprock wall so we could install cable tubes in the walls and he’s also getting more power points installed with us so he is really great thankfully 😅 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2676 Being an owner builder is no walk in the park. It’s a challenging endeavour that requires dedication and hard… 0 10013 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8284 |
