Browse Forums Building A New House Re: Lot orientation for future house E/W vs N/S 7May 10, 2019 10:52 am navman Understood Forg, but surely west facing in your example will have different sun path characteristics to north facing? For sure, but given how far south Sydney isn't, the sun is still surprisingly (to me) low to the north in winter. The sun comes around to that side of our house by about 2:30pm-3pm & the sun's just as low regardless of which direction you're facing, so best case is you'd get shading from that time, Google for stuff like sun angles, I can't recall what the search-terms are but once you know the angles you can draw it up pretty quickly with some simple diagrams and either a protractor or some simple trigonometry from high school. Most likely your house & theirs will be 1800mm apart, and most likely you'll only have to worry about the height of their wall closest to yours (6m-ish usually if I remember correctly but dunno your local regs). Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20667 0 623 Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4747 |
