Raft Slab - Pipe lagging
If you lag the pipes , termites can enter your home through slab penetration as they do on some older home when lagging was used.
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
23/07/2023
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
29/01/2024
3
I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to…
