Browse Forums Building A New House 1 May 01, 2019 2:58 pm Hi guys,
So I'm looking at buying some land. I found a pretty cheap one, and I think I've figured out why its cheap but I should be able to work around that. Have I got all my bases covered here?? Potential issues: 1. Acid sulfate soil. Will this affect site costs heavily? 2. An easement on the 1 side of the lot. Thats fine, its where I wanted my garden anyways, overlooking the river. 3. Only in the 0.1% flood risk area, and that is only for the lower part of the lot. 4. The slope and shape of the property I think is what puts most buyers off. It has a steep ~4m slope right at the road, then the property gently slopes down another 1.5 over the remaining property. The part I plan to build on should only slope about 1m. That shouldn't be a major issue? And will need to make some plan with the driveway to make the steep side accessible. I can only afford going with pre-designed homes so options are limited but Dixon has a few designs that suit this layout. 5. DBYD. A number of assets in the area but most are right up by the street or down in the easement, save for an "abandoned sewer line" which is in the way... Problem?? 6. No idea what utilities are connected. Is there an easy way to check this? Water, electricity, sewer, NBN, what else? Below is a child's drawing of my plan. Any suggestions, warnings, advice?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Anything I'm missing?? 2May 01, 2019 3:14 pm Should be ok, on the slope issue I recall my builder saying earlier on that the blocks that slope up from the road are cheaper to build on than those that slope down from the front....for some reason? --------------------------------------------------------------------- Check our Homeone build blog here Re: Anything I'm missing?? 4May 01, 2019 4:12 pm EdB84 Yeah if it were sloping upwards from the road I could just put the house on stilts and have the garage below... have you checked the flood map with council? Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Anything I'm missing?? 5May 01, 2019 4:16 pm SejaeD EdB84 Yeah if it were sloping upwards from the road I could just put the house on stilts and have the garage below... have you checked the flood map with council? Yep! All good, very slight risk on the lowest part of the lot. Re: Anything I'm missing?? 6May 01, 2019 4:22 pm EdB84 SejaeD EdB84 Yeah if it were sloping upwards from the road I could just put the house on stilts and have the garage below... have you checked the flood map with council? Yep! All good, very slight risk on the lowest part of the lot. awesome, just double check your council setbacks etc Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Anything I'm missing?? 7May 01, 2019 4:24 pm SejaeD EdB84 SejaeD have you checked the flood map with council? Yep! All good, very slight risk on the lowest part of the lot. awesome, just double check your council setbacks etc Ah thank you! I couldn't figure out what they call it here. I'm used to it being called building boundary lines. Re: Anything I'm missing?? 9May 02, 2019 9:35 pm You probably will need piers due to the trees being close to the building and also check the depth of the easements as the angle of repose may also need you to deepen the footings.This should all come out in the engineering design. To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11277 Yes, the builder is required to finish the wall. What else have you missed? 1 3365 |
