Browse Forums Building A New House 1 Apr 25, 2019 9:24 pm Received our Master plans, including Elevations, and seen for the first time that above the front entry door and also external laundry door, the drawings say “300mm Hilites Above Openings”. Our doors are standard 2030 high, while the house is 2700 high. Does anyone know what this means? Is it some sort of fibre cement infill? Re: 300mm Hilites above openings 4Apr 25, 2019 10:04 pm Bebbsy thme I think this is a fixed glass panel. Are you having aluminium door frames? The front entry door and laundry door are both wooden. All windows and sliding doors are aluminium. You can still have a hilite in a timber frame. I would assume that this refers to a fixed glass panel above both doors. Looks like this - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: 300mm Hilites above openings 5Apr 25, 2019 10:35 pm [quote="thme":385zcty1][quote="Bebbsy":385zcty1][quote="thme":385zcty1]I think this is a fixed glass panel. Are you having aluminium door frames?[/quote:385zcty1] The front entry door and laundry door are both wooden. All windows and sliding doors are aluminium.[/quote:385zcty1] You can still have a hilite in a timber frame. I would assume that this refers to a fixed glass panel above both doors. Looks like this - [img:385zcty1]https://forum.homeone.com.au/u/84712_1556193802.png[/img:385zcty1][/quote:385zcty1] We won’t mind if it is glass, just so long as it is not some sort of fibre cement sheeting. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20615 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9969 |
