Browse Forums Building A New House Re: Owner Build House - Denham Court 21Jul 08, 2019 11:42 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Owner Build House - Denham Court 26Jul 09, 2019 6:08 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Owner Build House - Denham Court 38Jul 31, 2019 2:38 pm darb74 Hi Tony Angievski, Looking at your front door sill, is that some form of 'capillary break' sitting under your bottom plates there? I am assuming the black stuff to the right there (under the bottom plates) is a DPC? Reason I ask is our builder didn't install anything under the external wall bottom plates, and my logic now would be to add something there to totally avoid any possibility of moisture making its way up from the concrete to the timber framing. Anyhow progress and quality looking good. Cheers Hi darb it's actually a termite barrier. Re: Owner Build House - Denham Court 40Oct 20, 2019 1:48 pm Been a while since I posted. Here is an updated photo of where I'm at It's all rendered getting painted on Tuesday. Front door in 2 weeks same as garage door. Should be at lockup soon. I used cladding on the outside called masterwall. 150mm thick screwed straight into the stud. One of the most energy efficiency things you could get. That with my double glazed windows never have to run the aircon. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3049 Sorry but you have a crap builder. Probably too late now. For our last build I only spoke to builders who would allow me easy access (at no cost). I used my own sparky… 10 9837 If so what were the "special circumstances" under which it was granted? "Note: If the development consent is for 'dual occupancy' an owner-builder permit can only be… 0 14074 |
