Browse Forums Building A New House 1 Apr 10, 2019 6:13 pm Anyone building a double storey home with a Maple staircase? Our staircase is stained Maple and glass. If you run your hand along the balustrade it is so rough you almost get splinters. The stain also looks patchy in the timber. Our SS has told us the painters who stain the staircase should have sanded it down however we will never be able to get a smooth finish? Is this correct? I would have thought that Designer Staircases ought to provide smooth finish in their staircases which are ready to stain without the need for further sanding. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 3Apr 12, 2019 8:16 am This definitely ain't a topic that's limited to a single builder! But yeah, as Joker said, it doesn't need to be sanded right down to being a perfect mirror finish; it should still have some of the texture of the wood. But nowhere near "splinters" roughness. It should be smooth enough that you wouldn't get any splinters nor would you feel your finger jag or catch if you ran your finger along it BEFORE it was estapoled/stained - and then the tinted clear-coat stuff over the top seals it & makes it that little bit smoother. Re: Building with Wisdom Homes 4Aug 18, 2019 8:16 pm Mish018 Anyone building a double storey home with a Maple staircase? Our staircase is stained Maple and glass. If you run your hand along the balustrade it is so rough you almost get splinters. The stain also looks patchy in the timber. Our SS has told us the painters who stain the staircase should have sanded it down however we will never be able to get a smooth finish? Is this correct? I would have thought that Designer Staircases ought to provide smooth finish in their staircases which are ready to stain without the need for further sanding. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey Mish018, Got any newer photos of your maple stain and finished stair case? What finish is used on the side? Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8206 |
