Browse Forums Building A New House 1 Apr 10, 2019 3:28 pm Hi there, not sure if anyone here has done this in the past. We are building a 52 square home and thinking to have a separate water heating for each floor. Main reason, when someone is using the bathroom (most especially kids) they are not interrupted when we are using the kitchen downstairs that uses hot water. It's always busy in the kitchen and with our current home that has 1 tank water heating, it's always a major concern. I'm not sure how much would it cost to have separate water heating but if you can also share a rough estimate that would be very helpful. Thanks Re: Building 2 storey home- separate water heating on each f 3Apr 10, 2019 3:42 pm ![]() Hi there, not sure if anyone here has done this in the past. We are building a 52 square home and thinking to have a separate water heating for each floor. Main reason, when someone is using the bathroom (most especially kids) they are not interrupted when we are using the kitchen downstairs that uses hot water. It's always busy in the kitchen and with our current home that has 1 tank water heating, it's always a major concern. I'm not sure how much would it cost to have separate water heating but if you can also share a rough estimate that would be very helpful. Thanks I can tell you exactly what it will cost ![]() I would recommend a B26 for upstairs which you can buy for $769 and a 32 litre for downstairs as you want to be able to run the washing machine and kitchen taps if needed. These are $1700 Re: Building 2 storey home- separate water heating on each f 4Apr 10, 2019 4:50 pm Thanks alex and sejae, very helpful. I'm glad that it is possible and it won't cost heaps. Such a great relief. Sunroom isn't going to get much sun. Except a bit in the morning. The main bedroom is above the garage, so you will want insulation in between your bedroom floor/garage… 7 1389 Thanks and I agree with all your points, very helpful. I have asked my builder if possible for them to relocate somewhere appropriate in the ground floor. I was more… 2 733 Thanks StructuralBIMGuy, The one I’m eyeing off is the Little Giant 17, it looks identical to your Werner even in functionality and rated to 150kg too. Have you… 3 2064 |
