Browse Forums Building A New House Re: Building near protected trees 10Apr 06, 2019 5:41 am For cdc have a look at clause 3.33 https://www.legislation.nsw.gov.au/#/vi ... /572/part3 You also need to check your local councils website as they should have clear guidelines for trees that aren’t covered by the cdc requirements A lot depends on which council you feeling to, where the tree is on your block, what species it is and how big it is. Good luck Our standard double-glazed window is tested to achieve, Rw 34, and can be glazed to suit Rw 39. The price is good too... 3 9472 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223606 |
