Browse Forums Building A New House 1 Apr 03, 2019 7:51 am Hi All, Any know why this Foam strip is used between the joint of two wall? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see this in multiple places where there is a corner joint. There is no Mortar/Cement used to connect them. If we remove the foam, we can see thru the hole. Will it be close later or left like that? Thanks Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 2Apr 03, 2019 8:35 am InvincibleInDN Hi All, Any know why this Foam strip is used between the joint of two wall? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see this in multiple places where there is a corner joint. There is no Mortar/Cement used to connect them. If we remove the foam, we can see thru the hole. Will it be close later or left like that? Thanks I would say check your engineering drawing. If that's not an expansion join I expect to mortar in there. Re: Question about Bricklayer (Pictures attached) 3Apr 03, 2019 10:03 am It's Abel Flex , used in between structures so if the concrete expands doesn't affect the other structure. I haven't seen it being used in between bricks thou. here is more about it. https://www.cornellengineers.com.au/all-about-abelflex/ Re: Question about Bricklayer (Pictures attached) 4Apr 03, 2019 10:09 am Ashwin It's Abel Flex , used in between structures so if the concrete expands doesn't affect the other structure. I haven't seen it being used in between bricks thou. here is more about it. https://www.cornellengineers.com.au/all-about-abelflex/ Its actually very common for brickwork expansion joint. They just seal it with color matching sealant so most times you don't see it. Re: Question about Bricklayer (Pictures attached) 5Apr 03, 2019 10:25 am MyFirst I would say check your engineering drawing. If that's not an expansion join I expect to mortar in there. The Engineering plan doesn't have anything mentioned about Bricklayer. The plan has details about Slab, Structural Steel and Site BAS/BOS Plan. Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 6Apr 03, 2019 10:26 am MyFirst Its actually very common for brickwork expansion joint. They just seal it with color matching sealant so most times you don't see it. I hope its the same thing you mentioned. I already have questions to ask list. Will ask my SA next time I meet him. Thanks Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Question about Bricklayer (Pictures attached) 7Apr 03, 2019 10:34 am InvincibleInDN MyFirst I would say check your engineering drawing. If that's not an expansion join I expect to mortar in there. The Engineering plan doesn't have anything mentioned about Bricklayer. The plan has details about Slab, Structural Steel and Site BAS/BOS Plan. Your engineering plan would mention where the expansion joints will be. Anyway, 2 possibilities, it will either be covered up with mortar (for corners) or sealant. (sealant is definite for expansion joint). Definitely they won't leave it like that. Re: Question about Bricklayer (Pictures attached) 8Apr 03, 2019 10:40 am MyFirst Ashwin It's Abel Flex , used in between structures so if the concrete expands doesn't affect the other structure. I haven't seen it being used in between bricks thou. here is more about it. https://www.cornellengineers.com.au/all-about-abelflex/ Its actually very common for brickwork expansion joint. They just seal it with color matching sealant so most times you don't see it. May be that's why I haven't seen them in between the bricks. Re: Question about Bricklayer (Pictures attached) 9Apr 03, 2019 11:47 am That's all OK, in terms of contemporary Australian building practice. It's an articulation joint at a wall offset where there is no lateral restraint requirement in the design. You don't want to think too much about why it is OK in terms of building practice. It's all to do with lighter-weight footings and foundations and a desire that movement in those elements not cause significant cracks in a building's visible masonry. There may be a lot more happening around that joint that you just won't see as a customer, things like flexible brick ties and slip-joint devices. Enjoy. Re: Question about Bricklayer (Pictures attached) 12Apr 04, 2019 4:26 pm InvincibleInDN Hi All, Any know why this Foam strip is used between the joint of two wall? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I can see this in multiple places where there is a corner joint. There is no Mortar/Cement used to connect them. If we remove the foam, we can see thru the hole. Will it be close later or left like that? Thanks They will use mastik or ableflex to fill the joint. Its an expansion joint so needs to be flexible and will look neat Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3401 Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18439 |
