Browse Forums Lighting + Lighting Design Re: Downlights. Need your advice. Some pics available. 11Oct 09, 2008 6:43 am I_BUILD Casa2 Antoxa, Honestly though the hassles are not worth it at all in my opinion. I think having two dowlights in each would actually look better and make the reccess stand out more. As for using extra power, 3 extra low voltage downlights will not brake the bank and if on dimmers then problem solved. to save power you could use these bulbs http://www.lighting.philips.com.au/au/en/Portal?xml=catalogue/lamps_family&fldr_id=3624&basetype=lamps Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23735 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15259 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7597 |
