Browse Forums Building A New House 1 Apr 01, 2019 7:46 am Hello everyone, this is my first post on this forum. I've done lots of reading and research and have been overwhelmed by the amount of info and great ideas this forum contains. I am in the process of starting a build (currently waiting on the tender) and was hoping to get some feedback on my proposed house layout. My block is back to south. Please note that I have extended the garage and laundry by 1M wide and have reduced the deptness of the laundry to make the garage a bit longer than the dimensions indicated. The garage is now 6 X 6.5. Looking for ideas in terms of windows positioning, laundry and anything else you can pick up. Any ideas will be welcomed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks in advance Re: Feedback on the plans 3Apr 01, 2019 9:04 am Couple of things that occur to me:
Re: Feedback on the plans 4Apr 01, 2019 9:31 am It is a good size house.
I would switch the dining and family room around and make the media room a bit more enclosed. You may want to check where the measurement for the family room is as it looks like it is to the bench top of the kitchen, which may make it very narrow. If you are wanting more light in the laundry, swap out the swinging door for a glass sliding door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I agree that a cavity slider in the downstairs guestroom to bathroom would work better, but I would also look at repositioning the door off the hallway to the end where the bathroom is and that gives you more space in the bedroom and a longer entry hallway where you can hang art. Just my thoughts. Re: Feedback on the plans 5Apr 01, 2019 9:35 am Switch the vanity and toilet downstairs, otherwise everyone walking from the front door will see the toilet if the door is opened. Not sure about your plans in the en-suite, looks like you have an opening door, just have a glass panel and do a walk in shower. Also maybe opening from garage to laundry, rather than into main entry hallway, use it as a mud room/drop zone and easy access to kitchen. Re: Feedback on the plans 7Apr 01, 2019 9:49 am Forg Couple of things that occur to me:
thanks for the quick reply. North is at the front of the house. The plan with the Theatre is to have it as a kids play room for a few years, wife wants a room visible from the kitchen to keep an eye on them. We could open it up later on if we decide to use the room differently, or even put sliding doors to close it in. The widow in the atrium is for the same reason, worried about kids falling off. Re: Feedback on the plans 8Apr 01, 2019 10:06 am How about replacing the atrium window with full-height, too-narrow-to-get-between pillars? You could probably make an interesting feature. Ah, rear to south, yeah I re-read that after I typed the question. In that case, is it possible to extend your porch, or at least just the roof over it, along the front of the study so as to shade it in summer & let sun shine in during winter? And fit widened eaves above the north-facing windows of the master upstairs as well? Bed 4's window probably would probably benefit from an external (but internally-adjustable) louvre/shade arrangement, and make sure that western wall has the best insulation you can get 'cos those bedrooms will get hot in summer otherwise. Might be worth asking the builder if they install something, cheaply, now, which would make the possible addition of sliding doors for the theatre cheaper in future? I don't know what - eg. maybe the right arrangement with a drop ceiling might cost little now but give you a hidden beam to which you could attach a fancy sliding-barn-door track in future? Re: Feedback on the plans 9Apr 01, 2019 10:10 am bestspecials It is a good size house. I would switch the dining and family room around and make the media room a bit more enclosed. You may want to check where the measurement for the family room is as it looks like it is to the bench top of the kitchen, which may make it very narrow. If you are wanting more light in the laundry, swap out the swinging door for a glass sliding door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I agree that a cavity slider in the downstairs guestroom to bathroom would work better, but I would also look at repositioning the door off the hallway to the end where the bathroom is and that gives you more space in the bedroom and a longer entry hallway where you can hang art. Just my thoughts. thank you for the quick reply. Do you mind clarifying "but I would also look at re positioning the door off the hallway to the end where the bathroom is and that gives you more space in the bedroom and a longer entry hallway", I'm not sure what you mean. I also don't like the robes just off entry but we need it for shoes/coats storage. We don't like wearing shoes in the house.Might just have to move them instead of the garage door and the garage door through laundry. Re: Feedback on the plans 10Apr 01, 2019 10:22 am Boro bestspecials It is a good size house. I would switch the dining and family room around and make the media room a bit more enclosed. You may want to check where the measurement for the family room is as it looks like it is to the bench top of the kitchen, which may make it very narrow. If you are wanting more light in the laundry, swap out the swinging door for a glass sliding door. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I agree that a cavity slider in the downstairs guestroom to bathroom would work better, but I would also look at repositioning the door off the hallway to the end where the bathroom is and that gives you more space in the bedroom and a longer entry hallway where you can hang art. Just my thoughts. thank you for the quick reply. Do you mind clarifying "but I would also look at re positioning the door off the hallway to the end where the bathroom is and that gives you more space in the bedroom and a longer entry hallway", I'm not sure what you mean. I also don't like the robes just off entry but we need it for shoes/coats storage. We don't like wearing shoes in the house.Might just have to move them instead of the garage door and the garage door through laundry. Sorry, I would place the doorway for the guest bedroom at the other end of that room (next to the bathroom door). And, if the back of your house is south, by switching the dining and family rooms, you will have lovely light in there in the morning. Re: Feedback on the plans 11Apr 01, 2019 11:27 am Forg How about replacing the atrium window with full-height, too-narrow-to-get-between pillars? You could probably make an interesting feature. Ah, rear to south, yeah I re-read that after I typed the question. In that case, is it possible to extend your porch, or at least just the roof over it, along the front of the study so as to shade it in summer & let sun shine in during winter? And fit widened eaves above the north-facing windows of the master upstairs as well? Bed 4's window probably would probably benefit from an external (but internally-adjustable) louvre/shade arrangement, and make sure that western wall has the best insulation you can get 'cos those bedrooms will get hot in summer otherwise. Might be worth asking the builder if they install something, cheaply, now, which would make the possible addition of sliding doors for the theatre cheaper in future? I don't know what - eg. maybe the right arrangement with a drop ceiling might cost little now but give you a hidden beam to which you could attach a fancy sliding-barn-door track in future? there is a balcony off the master bed, not on the plans but it will provide the required shade. Bed 4 is spare, not sure if we will ever use it. Insulation will be 2.5 throughout, hopefully enough. Now thinking seriously about swapping dining with living, we had that plan in mind too.....and now looking at it, it will probably be too narrow for a living room. Re: Feedback on the plans 12Apr 01, 2019 9:53 pm I would switch theatre and family room, make the new theatre a bit smaller than current family room and fully enclose and soundproof it. Just one small highlight window in there and more windows in family room. I can’t see how you’d have a practical theatre room otherwise. I’d think about a skylight above stairs but I can’t tell the roofline, north or south facing would be fine. Building Monte Carlo 40- Wisdom homes Feedback on the plans 13Apr 01, 2019 9:56 pm I would also cost out extending current theatre to be inline with alfresco. And another thing that looks good is extending the kitchen wall out 600mm so that the cabinetry sits flush with the dining room exterior wall. If you extended the theatre you could then consider making the bathroom a little bigger, so that you could have a separate powder room and en-suite for guest bed. Building Monte Carlo 40- Wisdom homes Re: Feedback on the plans 14Apr 01, 2019 10:03 pm Sorry one more. We store shoes in the under stair cupboard. You’ll be closely coming in via the garage anyway. We have a nook in the hallway for a hall table, which I think is more appealing than seeing a cupboard as you walk in. Building Monte Carlo 40- Wisdom homes Re: Feedback on the plans 16Apr 02, 2019 8:22 am Boro Thanks for all the ideas guys, I’ve got a bit of work to do Stick with your guns and go with the plan that suits your family the best. I look forward to seeing what you end up with. Re: Feedback on the plans 17Apr 02, 2019 10:16 am Boro Thanks for all the ideas guys, I’ve got a bit of work to do Just my 2 cents worth, back on your original floorplan, I too would swap over your Family room and Home Theatre. I would then move the adjacent wall between the two rooms to increase the size of the Family room at rear of the house. I would then enclose the Theatre room by adding a wall between the kitchen and Theatre, so it is soundproof. In relation to your wardrobes, if you stick with the swing doors, make sure they are the taller 2340mm high doors, this allows you easier access to storage space on the top shelf. Good luck! Re: Feedback on the plans 18Apr 02, 2019 11:04 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for the reply. This is the standard plan from which I modified. I had two problems with it, Dining table being in the way of walking through the house and second, the wall in the theatre blocks all the light in the kitchen/dining area, hence I turned the kitchen 90 degrees and swapped family with theatre. I am now leaning towards having family between kitchen and alfresco and dining where the family is (on my modified plan) and potentially extending the theatre towards the back a bit. I'm not planing to use it as a theatre room as such, more like a games room/tv room. Re: Feedback on the plans 19Apr 02, 2019 11:11 am To be quite frank, this house design has a lot of problems with it. The spaces are very small and not well thought out. It will be cramped and awkward. Are you able to step back and look for other house plans that suit your block? I think you need a better starting point to work from. How big is your block? Re: Feedback on the plans 20Apr 02, 2019 11:32 am Have a look at the attached rough sketch. By taking away storage space from the garage you can fit a better sized theatre at the front of the house. You can then use the previous family space as a study/ playroom which is much better suited to the dimensions of the space. You are then left with a generous sized family room that can be easily furnished. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17866 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13443 |
